Water spots on finish
Jack Guzman from Maine
I have a table that has water spots.They're white rings. I wiped with alcohol and the spots disappeared but they came back after the alcohol dried. The finish doesn't get sticky with alcohol or with lacquer thinner.It is glossy and has tiny cracks in the finish from age. The client wants me to remove the finish and use something that won't be affected by a glass being set on it. This a coffee table that gets alot of use by house guests. I'm not sure how to proceed and I don't want to start stripping until I get more information.Help?---Jack
Re: Water spots on finish
Dave Paine
A number of products on the market for water ring removal. I loaned one out so do not recall the name.
If one of these worked it would save a lot of trouble.
A potential headache of stripping is matching the colour afterwards.
If the person wants to have water sitting under objects for a long time, this will be a problem for most finishes.
I think an epoxy type of finish would give the most water resistant finish. This is normally applied thick. Look for bar top finish.
Personally I would not place objects which can drip water directly on my wood surfaces, no matter how I finish. This is why I use coasters or mats.
Good luck.
