Speedaire compressor
Thomas Norton
Anyone have this brand of compressor? I am thinking of upgrading from my Craftsman unit.
Re: Speedaire compressor
Grant in Iowa
Several of my contractor friends use speedaires. No complaints and several endorsements of them is what I hear.
Look for oil bath compressor "engine", belt drive and brushless motor for less annoying noise while it runs. A plus is 220 powered or convertible, so the lights don't dim when they start up.
Good machines from what I hear and have seen.
FWIW,
Grant in Iowa
I've used a couple...
John in NM
They're Granger's house brand. No idea where they're made but they're good units, we had two in the last shop I worked for, about 10 years ago. Last time I was in there they were both still kicking.
I don't know if they make diaphragm or other "oil-less" high speed compressors, but stay away from those regardless of brand. I've found the iron housing, oil bath compressors to be pretty much bullet proof, whereas even the best oil-less I ever owned needed a rebuild after 15 years ( :D - I should have kept it anyhow, it was a pretty good one).
Another favorite of mine is Rol-air, pumps are made in Italy, the rest in the USA. You can get them at contractor suppliers, White Cap is Home Depot's pro tool house, they sell to pretty much anyone, but its a warehouse style operation, don't expect to browse much.
Re: I've used a couple...
FredD
Campbell Hausfield used to make Speedaire, I assume they still do.
FredD
I had one and would recommend it.
I had a 2 hp Speedaire with about a 20 gallon tank and it worked fine for many years. Don't forget to drain the condensate regularly.
Jim DeLaney, Austintown, Ohio
Re: I had one and would recommend it.
+1 on drain that tank!
I had what sounds like the same Speedaire unit that Ellis had. I had it for about twelve years, and bought it used at a liquidation auction at a semiconcuctor factory. I'd guess it was fifteen (or more) years old when I got it, and it had - no exaggeration - half a gallon of water in the tank. I doubt it had EVER been drained.
I put an I-R automatic drain on it, and used it for twelve years until the tank developed pinhole leaks, and I replaced the whole compressor with a new unit.
BTW, about a year ago, I had a friend get very seriously injured when a re-welded tank on his compressor blew up. He was probably twenty feet away from it, but caught the wheels & axle upside his head. Damn near killed him! He also got a piece of the tank in his leg, and some other less serious punctures and abrasions from it. A rusted out tank just ain't something to mess with!
