Drawer Faces: How much overlap?
Ed
I'm designing the drawers for my workbench and i'm trying to figure out how much of an overlap to have on my faces.
This is what I'm planning, any comments?
* Drawer dimensions 19" x 15" x 3 1/4" (outer dimensions, the 1/4" is because my jig recommends a whole inch and then add a quarter)
* Board thickness: 1/2" (Should I use 3/4" for a workbench crawer?)
* Bottom thicknes 1/2"
* Groove for bottom cut 1/4" above the bottom of the sides.
* Faces 19 3/4" x 4 1/4" giving me 3/8" overlap on each side and 1/2" on top and bottom. The 1/2" on top and bottom is to give me 1" between the drawers, which I'll need for space for the sliders on which the drawers will slide.
* Faces rabbeted so they'll slide into the bench by 1/4".
Anything in these numbers look like a bad decision?
Thanks.
Ed
Re: Drawer Faces: How much overlap?
Joseph Mulherin, Sr
I think your deminsions are satisfactory for the drawers. I am remaking my shop and work bench too and shall try to make my drawers the same way. The older ones were satisfactory for the time I had them, but things have to change....probably best for both of us in better arranging of tools etc.
Moses Yoder
Moses Yoder
What kind of slides are you using? Is the 1/4" from the bottom enough for the slides to work? If they are undermount slides the bottom usually needs to be 1/2" up.
Bartstar
I typically use 3/4" poplar for making my drawers, and 1/4" plywood for the bottoms. I always cut the bottom back edge of the drawer in line with the drawer dado so I can slide in the bottom after the drawer is assembled. Then I screw the bottom panel to the back edge. This allows me to replace the bottoms if they ever get damaged.
In general, I use a 1/2" overlay for my drawer fronts, but for my workshop, I used inset drawer fronts to cut down on the amount of dust that would settle on the drawer fronts.
Good Luck
Bart
Ed
Thanks to everyone, I've uploaded some images of my plans to my photography site.
1 - Overview. The drawers have outer dimensions of 9 x 15 x 3 1/4" with the sides and bottoms planned for 1/2". http://edbeck.smugmug.com/Woodworking/Woodworking/01Overview/1139741355_TAVGX-L.jpg
2 - Detail of how I plan to put the bottoms on. http://edbeck.smugmug.com/Woodworking/Woodworking/02Bottom/1139741369_ZgmXc-L.jpg
3 - The face and how I plan to rebbet it. I hope that this keeps dust out of them. http://edbeck.smugmug.com/Woodworking/Woodworking/03Face/1139741371_xSKAS-L.jpg
4 - The sliders are 15" long by 1" wide and 7/8" deep. This gives me 1/8" between the top of one drawer and the slider of the drawer above it. Is this enough? http://edbeck.smugmug.com/Woodworking/Woodworking/04R/1139741381_cvZUE-L.jpg
5 - Closer view of the sliders.
http://edbeck.smugmug.com/Woodworking/Woodworking/05Slider-detail/1139741383_ai8Bg-L.jpg
I'm planing the boards down to 3/4" then I'm going to check here to see if many think I should stop at 3/4". If not I'll take them down to 1/2".
Thanks,
Ed
Ed Beck
refreshing cookies
Bartstar
I think I can make those drawers using dovetails in less time than it took you to make those drawings. :)
Bart
