We value your privacy.
Fein is having a sale for the next day or so on the Multimaster, and I may be tempted. I have heard their patent has expired, and there are other options available. I am curious about how users may feel about the Fein, or other similar tools.
on what you're going to be using it for. An occasional job once a month, I'd say save some money and look at one of the lesser models.
On the other hand, if you're like me and use it on nearly every project in one way or another, spring for the real thing. Mine's been through two home remodels, acres of wood flooring and many small jobs I didn't even know it would do, and it's still going strong. Built like a tank, never overheats no matter how hard I beat it and it's got a ton of blades and accessories.
Having run many comparison tests of portable power tools for various magazines over the years, I can tell you that the one dimension we can never reliably test is how long the tools will last in normal use. Outwardly, they may look and perform very similarly, but when you get into the inner workings -- bearings, wiring, gearing, material quality, etc. -- I have found that a rule of thumb is you get what you pay for. I'm speaking in generalities here because I don't own a Multi-Master type tool.
Like Doug said, if you are going to be using it only rarely then go with a cheaper unit. they have one at the Harbor Freight that might suit your needs...
at most about $85.00...another for even less. Sears also sells a unit; as well as Dremel at Home Depot...about $100.
Resist the temptation to waste money. There is a reason why during a half hour infomercial they can't even replace one tile or sand more than 3 inches of molding.
If you can't, reconditioned Dremels sell for less than $50 on Amazon.
and it sits in a box on a shelf. It lasted all of 6 weeks before it let all it's blue smoke out. Once the blue smoke was out, it only runs at one speed. That speed could be tracked with a sundial.
I bought a Fein. It works like a champ. The blades are pricey but other than that, I've got no complaints. Vastly superior tool.
Andy Halterman
Grazing on Christmas cookies in Hendersonville, NC�
And have no complaints. I bought it at Lowe's on a close out. It has the L-ion batteries. When I got it, the charger did not work well and Bosch sent me a new battery. No help, so they sent me a new charger. Now it works perfectly and I have three batteries. Works like a champ, and I can not imagine how the Fien could be better. The only thing that might be better is that apparently Fein as a quick change lever release for the blades and on the Bosch has an Allen Screw, so changing the blades is slightly harder. The Bosch will accept nearly everyone else's blades. All of the blades are too expensive. Harbor Freight has cheaper blades, but they sell them in packs with one saw and two or three scrapers. I get a lot more mileage out of the saws.
As an aside, I find the tool to be amazingly useful. I bought it at a discount and though I might find a little use for it. Both my son and I are impressed with how useful it is and how many things we find to do with it. We have used it remodeling two houses, building a deck and several shop projects. I highly recommend the tool in general and the Bosch in particular. I think I might get the corded version just because I love battery tools, but hate the batteries. OTOH, I have truly enjoyed the one I have and it has done everything I asked. It's a year or so old and going strong. The Fien might be better, but I have not seen one.
I too have the Bosch, and the Fein. I like both but they should almost be considered tools for different purposes. I've had the Fein for ten years and have used the heck out of it. I got the Bosch when I bought the rest of their 12v (10.8v) tools last year.
The Fein does every thing it is advertised to do and does it well. The Bosch does almost everything the Fein can do only slower and in spurts; after all, it's cordless. I grab the Bosch for small jobs in the house or at the neighbor's or for very small needs in the shop. It will only cut for about five minutes or less before needing a fresh battery. It will last longer when sanding. I use it often because it is very convenient.
The multimaster will run forever and excels at everything it does. Now Bosch has introduce a small adapter that allows you to use their blades and attachments on all other machines of this type. I haven't bought it yet but it sure sounds promising. Fein should give you their multimaster for free if you agree to buy their blades; they are all horribly overpriced. Others here have mentioned that the Harbor Freight blades and attachments work well for the price. I haven't tried them.
Again, the Fein is a tool that will last you a lifetime. The Bosch does a reasonable job and is just plain convenient for small jobs.
MIKE I boughtn one about a year ago, but I haven`t used it to much as of yet, but it seems to be pretty heavy duty. The only thing I don`t like is the blade changeing device. You have to take an allen wrench to change it, it a PITA. But for the price I`d buy it again. Larry
BTW Amazon currently has the Fein for $193 w/blades. There has also been a $50 Fein rebate coupon floating around the internet. If they work together; I don't know.
Then there is always the 10% further discount available if you sign up for Amazon's credit card.
Geeez, I'm starting to sound like one of those posters on slickdeals.net!
Re: BTW Amazon has the Fein for $193 or less w/bla
I agree with all Scott said. I don't have both tools but I am sure the Fine is superior to the battery powered Bosch in that it will run as long as you have power. OTOH, as much as I love/hate battery powered tools, this one has been excellent. Bosch told me the run time on the batteries is about 17 minutes and they recharge in about 30 minutes. So, since I have three batteries I seldom run out. I almost never run the tool continuously, so even with two batteries, the other one charges about as quickly as you sue up the one in the tool.
I find it to be a tool you use in bursts, not for the long haul. I undercut door facings with it and cut off seven doors with two batteries. Nearly made it on one. To me its something you use a minute here and a minute there. I suspect I would like a corded one as well or better, but the convenience of picking it up, making a cut and moving on without having to find a cord and plug is worth a lot.
Mine came with the adapter plate and so far I have used Harbor Freight blades (MUCH cheaper, don't last as long, but an excellent value), Dremel blades, and Bosch blades. All worked fine. Have not tried it as a sander yet, but the attachment came with it. I paid about $90 for mine on close out and would have a hard time justifying another hundred for the Fine, but it might be worth it.
We like the little batteries so well that my family gave me the impact driver and the drill for Christmas. So now I have seven batteries and three chargers.
I don't know what the other tool is, but Loses has a combo kit on the Bosch. It was a bargain compared to the multi tool alone, but I don't remember the price.
Get a substitute - big time. I've got and had the Fein for several years, and have used it a lot. I have tried their star adapter, I have used compatible blades - I have done everything you can do with one I think. And let me be clear...
Their mounting system totally sucks. At least on my 636 model. Loose, Loose, Loose. No matter how hard you tighten, no matter how gently you cut, scrape or grind, whatever blade you are using comes loose.
their solution by email and on the phone was "Buy our new model". They do not have a better replacement head, and only came out with the "star adapter" after numerous complaints.
Their pricing is also a couple times that of their competitors. I will honestly be glad when this tool dies, and may scrap it before that. Hate to do it due to all of the blades that I still have, but I will not be buying any more blades. When the blades run out - so does the life of this too. Larry
I, too, have an older model. Not sure of the number, but it predates the star mount. I complained about the loosening blades to the Fein folks at IWF about 4-6 years ago, and they sold me a carbide grit washer for about $7, as I recall. I thought that, under the circumstances, they should have provided a couple to anyone who bought an early model, gratis.
Nonetheless, the carbide grit washer works well. I cut some old heavy, '50s era ductwork with it, using a round metal-cutting blade. There was a lot of binding and shaking, almost to the point of knocking me off the ladder, but the blade held.
I haven't seen all of the imitators, but one seldom regrets buying the best.
