REAL MILK PAINT
Maxi-cut Forstner bits
Howard Norman
I bought a couple of Colt Maxi-cut Forstner bits recently to make some pepper mills. Found that the shaft wouldn't fit into the bit extender that I own. On line looking found the Maxi-cut brand extender and bit holder for a Morse taper. Has anyone used this system? It is pricey but should be reproducible and possible more accurate.
Re: Maxi-cut Forstner bits
Stuart Hough
Howard, they have their own proprietary extenders that work on a sort of eccentric engagement system. Pricey, but they hold up real well.
Phil Joines
If it were me I'd return them and get some with 3/8" shafts.
I just bought a couple Colt bits, too, along with the extenders and a Morse taper adapter for my lathe. The cam system works very well, but I could see right away that you don't want to be using these bits without one of the proprietary adapters, as any galling of the shank would render the cam system useless, not to mention that I don't see how you could center the bit in a conventional three-jaw drill chuck, since the cam has two opposed lobes.
I bought the bits because they work really well for endgrain drilling.
Howard Norman
Thanks all. I went ahead and ordered the Colt Morse taper adapter and the Colt extension last night online. Not cheap.
