A Bevvy of boxes
A Bevvy of boxes
A Bevvy of boxes
Grant in Iowa
My lovely wife and I have made it a habit of making a bunch of some project each year to give as gifts. This year was no different, except we upped the production numbers a bit.
We have 17 boxes similar to these in various stages of completion, or already given as gifts.
They are cigar box sized, made of various hardwoods, and are lined with Elvis-worthy blue suede. The tops are all solid wood, sliced thin and prefinished before assembly of the boxes. The box stock was also prefinished to minimize the work required on the inside of the boxes after assembly. Once glued up, splines were cut in and the outsides of the boxes were then sanded and refinished with several coats of wipe on poly. The final coat was rubbed out and wax was applied to give a nice smooth surface that begs the touch.
Here are some photos of the five that are completed but haven't gone out the door yet.
While it is a lot of work, I always enjoy giving things we've made to friends and family.
Regards,
Grant in Iowa
Re: A Bevvy of boxes
question
Bill Tindall
Looks like there is some sort of interlocking of lid to bottom? How is that "joint" accomplished? One often assembles the box and then saws it apart which would not result in the rabbited edge I think I see.
I am in awe of the project.
That's a nice batch o' boxes
Bruce, a MN Galoot
I'd be glad to be on the receiving end of any one of them!
Re: question
Bill, I am not Grant, but I can tell you how to cut the rabbeted joint after assembling the box in one piece. I made about a dozen last year for Christmas
Assume you are going to assemble the boy out of a piece of stock four inches wide and long enough to wrap all the way around the box. Cut a rabbet on the inside very slightly over half the thickness of the stock just exactly about where the top of the bottom will be. Cut the miters and wrap the pieces around to form the box. You will need rabbets for he bottom and perhaps the top. Assemble the box around the top and bottom. Then, Remembering where the rabbit is inside the box, saw the lid off by cutting half way through from the outside just below the rabbet on the inside. Use a good blade for this, perhaps a rip blade that cuts a flat bottom cut, not that raggedy a$$ 7 1/2 skill saw blade you usually have on your saw. By playing with the width of the two rabbets you can set it up so that the lid closes tightly onto the bottom or you can leave a consistent gap like a rabbet around the box and celebrate the join. Draw a cross section of the side and visualize the cuts. Its actually easy if you don't lose tract of where you put the inner rabbet.
Using a single piece of wood allows you to wrap it around and carry the grain around three of the corners with only the fourth one mismatched. If you are willing to resaw the stock you can match all four corners. I can do it easier than describing it. Say the box is nine by twelve. Take a piece of stock 12 plus 9 plus a little for saw cuts, say 21 1/2". Resaw it right down the center. Take the one one the left and set one the other side so that the two sawn faces are now the exterior and the two original faces are touching. Cut an end and the front out one piece so That the end is to the left, cut the back and other end out of the other piece so that the back comes form the same end that the end came from. Miter the corners and the grain will wrap all the way around.
Wish I could draw these out for you.
I made a pair of boxes that were book matched anyway you turned them. Gave them to my cousin and her long time significant other. Later, they split up and each one has a box. I don't miss him much, but I do miss the box. the one by itself is not nearly as impressive as the pair.
It is clear except
Bill Tindall
I have a very high quality CMT 7 1/2 " blade on the saw. But for this operation one would need to make a wider kerf that this blade makes. But for just precision sawing boxes in two the CMT is hard to beat.
Bill is right on the money with the how its done..
Grant in Iowa
I would add that making boxes in this way is an exercise in doing things in the right order.
1. Select, face joint, resaw stock for the tops, keep bookmatched parts together. I resawed about 1/4" thick and then sanded smooth and to about 3/16" at the drum sander. Edge joint and glue up top panels. Cut to rough size, and and finish panels.
2. Select, face joint, edge joint, resaw and plane stock for box sides. Bill is correct in that you want the grain of the wood to run around the outside of the box. My stock would not permit the bookmatch continuous grain all the way around trick due to lack of thickness. Ah well, 3 out of 4 is still impressive to everyone but Bill and folks like that.
3. Decide on final box size and from that determine the final dimensions of the bottom and top box panels. I used 3/16" ply for the bottom panel with nice blue suede from Tandy leather glued to it using spray adhesive. Cut to size and glue on leather. Measure total thickness of bottom with leather affixed. Apply blue painters tape to cover leather to protect it from glue squeezout during assembly.
4. Examine stock to select the show or outside face of the box body. On the opposite side cut 3 rabbets (I just use multiple passes with a high grade rip blade). The 3 cuts are:
A: one to fit the thickness of your top stock, and made about 3/16" below what will be the top edge of your stock
B: one to fit the thickness of your bottom stock and leather and made about 3/16" from what will be the bottom edge.
C: one to cut halfway through from the inside of the stock at the point you want to separate the lid later. We'll call this the "lid release cut"
5. I prefinished the cut stock with 3 coats of wipe on poly and I took the time to rub out the inner surface of the box and WAX IT! , since it is easier to do so now then to try to get into the corners later. The wax also prevents the inevitable glue squeezeout on the inside of the box from sticking, making it easy to remove once you cut the box open.
6. Cut your miters making sure all equipment used is aligned, cutting cleanly and without tearout. Save the offcut for table saw setup later in order to make the second half of the lid cut.
7. Check fit before gluing. I use the packing tape method for the glueup, supplimented with stretch wrap to add extra pressure as needed to close the odd pesky miter perfectly. Obviously install box bottom and top just before rolling up the outside of the box. Make sure to check that your bookmatch and bottom are right side up. Bookmatches that are 1/4" thick have a right side and a not quite so right side.
8. Once glue dries, remove packing tape and clean up corners of box in preparation for adding splines. I cut the spline slots at the table saw using a jig that holds the box at 45 degrees to the saw table. The jig rides on the biesemeyer fence. I use a rip blade to get a flat bottom cut.
9. Make the stock for splines. I always make "too much" of the stock and store the unused portion to make the next spline job go faster. I cut little triangles of stock for the splines and glue them in place. No clamping is necessary.
10. I clean up the excess spline material and glue squeezeout at the router table with a bearing guided straight cutting bottom bearing bit. I have added a tiny strip of packing tape to the bearing ("1 time around" ) so the bit doesn't cut too deeply. If your spline stock sticks out more than 1/8" or so, visit the bandsaw first to trim it close.
11. Sand the outside of the box to something like 180 grit to flush up the splines and slightly round the sharp edges and corners. Yeah, you are sanding most of the finish you already applied off. I finished all sides of the box side stock beforehand to limit movement in the wood during construction.
12. Now, using a piece of off-cut box side scrap as a guide, set up your table saw to make a complimentary cut to your inside lid release cut halfway through the box all the way around. If you set it up right and scratch your head enough and do enough test cuts on the offcuts, you will be left with a nice lip to catch the box top. I actually endeavor to cut "not quite" all the way through so the box lid doesn't fall off when I make the final pass. Then I use a sharp knife to cut the final gnats whisker to free the top.
13. Clean up the fit of the top to the box using sandpaper, rabbet plane, or chisel. Clean up any glue squeezeout on inside of box with a sharp chisel. Sand to 220 or so leaving the already finished inside of the box and top panel alone and then 0000 steel wool to make it easier to see any scratches where you may have imperfections. Begin applying wipe on poly or finish of choice until satisfied. I always rub out the final coat with 0000 steel wool and then wax and hand buff to a nice shine and smooth surface. I make sure I use plenty of those blue shop rags from Sams club just to annoy those who think it is a bad idea for some unfounded reason.
14. Using a sharp knife, cut through your blue painters tape along the inside edge of the box and peel off the tape leaving a nice clean blue suede that Elvis would go nuts over. He'd probably have one of his "people" have a pair of shoes made out the stuff if he had half a chance.
15. Make and install handle as you see fit. Wax it again since you grubbied it up installing the handle. I blow the blue suede clean with a blast of air compressor air, which works great.
It's just that easy
Regards,
Grant in Iowa
Virgil Johnson
Nice gifts. Do you need my address?
Re: Bill is right on the money with the how its do
paul in AZ
Lovely boxes Grant, and a very nice description of the construction sequence. The suede is a nice touch. I've used felt but suede sounds better.
I have built several of these that way and am now in the process of another using resawn and bookmatched windfall mesquite for the top panel and hickory heart wood for the box.
One thing I am trying this time is making the slots for the miter keys [splines] skinnier and a little less prominent. Once the sides are mitered but before glue-up I have experimented with carefully stacking each joint against the bandsaw fence to cut the slots for the keys -one corner at a time. The BS kerf is < half as wide as the table saw's. On a trial piece I have glued up the miters so that the slots align. Keys go in after glue-up. I still haven't tried that on the final product. The worst case is slight mis-alignment, in which case I think I could resort to the table or hand saw to enlarge the spline slots.
Another decorative option that won't work with the narrow slots is to cut the key (spline) material very thin and out of two different colored woods. That works with a tablesawn slot.
Have you ever done the bandsaw slot thing?
Ray Carson - Lawrenceville, NJ
Very nice Grant.
Grant in Iowa
Hi Bill,
I haven't tried using a bandsaw to make the spline cuts, but I would suggest an alternative solution:
Consider using one of the new thin kerf Freud circular saw blades. Our local industrial supplier has a large selection of these and the kerf is about 1/16" or so. These can be put in the table saw with no problems.
Whenever I cut these, I try to back up the exit side of the cut with scrap of with a sacrificial jig fence to prevent tearout and minimize sanding.
FWIW,
Grant in Iowa
dang Grant
ron
Those are beautiful, but I'd trade any one of them for that 15-point guide you just provided. Thanks!!!
