Latest wood storage rack *LINK*
Dave Paine
After struggling with a portion of my wood inventory which was piled against a wall and not easily accessible, I was inspired by a ShopNotes picture to make a mobile wood storage rack. I am not getting younger and sometimes moving things to get to the one piece can be more than a hassle.
The ShopNotes design appeared to be mostly a plywood project.
I wanted something more solid, which could accomodate boards, full sheets of plywood and vertical storage for the mounting off-cuts.
This is the almost finished rack. Eight swivel casters mounted on a 4x4 frame. Plywood deck and 2x4 for the uprights and board storage. Behind the rack is the wood which needed to be organized.
The back side in the picture does not have the 2x4's to hold the 4x8ft sheet goods.
This is the finished rack with the stack of wood moved onto the rack. Easy enough to move once the casters swivel in the desired direction. I was hoping to avoid a handle, but found this to be less than ideal. Later I added 2x2 pieces to make an upside down "L" attached to the side. Much easier to move and added some rigidity.
The unit just fits under the wall shelve storage, which I can finally access.
This is not fancy, but very functional for my needs. I am happy to finally have easily accessible storage of the off-cuts. The ShopNotes design had distinct sections. I felt I would likely have pieces which were too wide for a given section, so I have full length access. This works for me. I was also able to put to good use some 4x4's and plywood which were left over from a project many years ago.
http://www.shopnotes.com/issues/055/extras/roll-around-store-all/
