Request Advice on Leg Joinery
Brint in Richmond, VA
My wife has asked me to make her a desktop Zen Garden, and I thought these legs would be in character:
All the elements of the legs are 3/8" square in cross-section. However, when it comes to figuring out the best way to join a bunch of 3/8" square matchsticks, I'm a bit stumped. The only way I see is to make the corner posts, then butt-joint the two arms to that, and then butt-joint the two "risers" onto the ends of the arms. Would this be okay? Any other suggestions?
As always, thanks for the help --
Re: Request Advice on Leg Joinery
Keith Newton----Little Rock, Arkansas
Start with 1 1/4" stock, and just saw it out with the bandsaw, or even use a Table Saw with a 3/8" dado, and sled.
David Hay Denver
If you want to make it out of individual pieces, I'd look at using a half lap joint. For the central post, you'd cut a dado on two faces to receive the mating half of the crossing half lap.
David
Lee Grindinger
I think I'd go one step farther
Lee Grindinger
I'd consider sawing the entire side including the legs from a single piece of wood eliminating a joint altogether.
Lee
