Do we have an astronomer?
There is a lunar eclipse tonight. Naturally, my question is not about that. what I am curious about is a solar eclipse. When the moon passes in front of the sun, how close is the fit? Is the moon exactly the right size to cover the sun? Is it a little bigger than it needs to be or a little too small? Does it vary depending on how far the Earth is from the sun? Just pointless curiosity as winter starts.
Re: Do we have an astronomer?
R Payne
The answer is sometimes it is total as in the moon totally blocks the sun. Sometimes the moon isn't quite big enough to cover the sun completely. That is called an annular solar eclipse. The reason for the variability is that neither the moon's orbit around the earth nor the earth's orbit around the sun is perfectly circular. Both are ovals defined by the masses of the said celestial bodies (as well as the effects of the other gravities out there) and the distances between them.
Does that make it clear as mud?
ron
Keith Newton----Little Rock, Arkansas
Yes Barry, the Sun and Moon both are ~ 3/4�, but the Moon's orbit is pretty elliptical, so when it is close, 225,000 miles, it can totally block it out.
Other little tidbits. The Earth rotates 1� in 4 minutes, or 15� per hour.
The Moon rises ~49.6 minutes later each evening, so it is traveling around Earth opposite of the way the Sun and Stars appear to travel.
If you could look down on the Earth orbiting around the Sun from far enough out in space from near Polaris, the Earth would appear to travel counter clockwise, and the rotation would be like it was rolling along. Thus, when the Sun sets in the evening, we are on the back side of the way we are traveling, and on the front side of travel around daybreak.
The Stars appear to rise 4 minutes earlier each evening, so the constellations move across the sky ~ one degree per day, East to West. A lot of these observations vary relative to latitude of course, since everything just appears to travel in a circle if you are at the poles.
