Probably not Festool-approved (phenolic followup)
Henry Higginbotham
I posted a question a while back about cutting phenolic. Thanks again to all who replied. I ultimately used a router for the entire work.
When I bought my OF 1400 router, I got the edge guide and the guide stop, but did not get a trammel (it looked kind of rinky-dink, though I'll bet it works fine). But I found myself needing one for cutting the phenolic, so I temporarily modified the guide stop by popping the top off one of the clamping knobs and replacing the 40mm cap screw with one 10mm longer. The M6 screw drops snugly into a 15/64" pivot hole. This setup allows you to use the micro-adjust screw in the guide stop.
Again, I suspect this isn't Festool-approved, but it's simple and quick, and appears non-destructive. The maximum radius would be about 16.5 inches, if the outside clamp screw were replaced. I only needed 5.5 inches, so I used the inside one.
Here's the screw:
. . . and the assembled unit (and, yes, I put plywood under it before I got near the bottom!):
Re: Probably not Festool-approved (phenolic followup)
FredD
Excellent Henry .
FredD
mdclor
I love my Festool router, but what you did would cost $187.50 or more if purchased from Festool. :D Great solution on your part!
Henry Higginbotham
Festool's site shows a trammel attachment for the OF 1010 router for $20.50. It's basically just a single rod with a pin at the end, but it probably works better than it looks. However, they don't show it as an accessory for the OF 1400, so maybe it doesn't fit that one. In any case, I liked the solid feel of using the guide stop, and I imagine the micro-adjustment wheel would be handy for some applications.
Jesper, Denmark
Jesper, Denmark
Hey, It's your router and it worked well, so who needs approval?
Rick Christopherson
This is a great tip, and as long as it is non-destructive, Festool would very likely embrace it. They like seeing creative ways that people find for using their tools. You should post this over at the Festool Owner's Group forum. http://festoolownersgroup.com/index.php
