How to Make Fluted Pilasters
Bartstar
I would like to make some fluted pilasters to add some decorative elements to the vanites I'm making. I was planning to use a small cove bit on my router table and adjust the fence to create 3 flutes.
Question - how do you create the tapered ends to the flutes?
Thanks
Bart
Re: How to Make Fluted Pilasters
Lee Grindinger
Gouge
Lee Grindinger
I did an awful lot of these. I'd use either a router with a core box bit, or a moulding head in a table saw to cut the flute, then a gouge to finish the ends, if I remember correctly a #6, 1/2" gouge worked perfectly for a 1/2" flute. I can post a pic or two of the finished product if you like.
Lee
If you go berserk,
and use a capital and a plinth - head and foot - to reference classical columns, you can also run the flutes straight through.
William A. Roland
Re: How to Make Fluted Pilasters *LINK*
William A. Roland
You need two 2X4's od 2X6's with 30 or 45 degree angle cut on them. They should be long enough to clamp on your stock and allow router to ride up on them at the ends tapering the ends of the flute. You may have to practice on sample stock to profect the procedure. Link is to some I did this way.
Fluted cabinet
