Clamp Advice Needed.
Thomas Norton
I have a shop built slot mortiser and need a bit of help with a clamping idea.
I have the type of clamps,cannot rememeber the name, where you flip the handle and it pivots down to hold the work down. I have 2 of these mounted to plywood squares that have "T" bolts and track.
The problem is I am limited to the thickness I can clamp. The other day I wanted to mortise some slots in 1 3/4" legs and it was a no go. So I did it freehand just to get it done as I did not want to take the time to work out an alternative.
So any thoughts? On some of the commercial models I see some type of post with a clamp on it.
