accuride drawer slides
David Dircksen
I put accuride drawer slides on a dresser I made, everything seems to be pretty square but one side of the drawer doesn't close tight. Did I do something wrong or is ther a trick to mount the slides?
David Dircksen
Re: accuride drawer slides
David Hay Denver
What do you mean by "won't close tight"? Is is possible that the slides on that drawer are mounted a hair closer to the front than the other drawers? If you slide them back a bit, would the drawer close? Are you sure that they're mounted parallel to each other and square to the front of the dresser?
David
Moses Yoder
As mentioned, it is critical that the drawer is square, the opening is square, and the slide rails are set the same distance back from the front of the box and the slide from the front of the opening.
