Double sided tape recommendation for pattern routi
Bob Willey
What is your recommendation for a double sided tape to be used for pattern routing? I'd like to get a specific brand since there seems to be a lot of choices out there. Thanks.
Bob Willey
Re: Double sided tape recommendation for pattern r
Dave Paine
I have a 2in wide roll of 3M Scotch double sided carpet tape which I use for holding pieces to a subase for routing, sometime for mitre cuts where not enough length to clamp.
If the piece is flat this provides enough holding power for me and comes off without leaving adhesive behind.
I likely purchased this for the carpet use some time ago and then one day looked to see what I had on hand for holding some wood piece for routing.
McKay
I purchased some yesterday from "Craft Supply". http://www.woodturnerscatalog.com/
I was shocked at the price, but it is very good tape. I have had some from other sources that you were not able to get the paper off very well. No affiliation with the company.
Jerry Gibbs
If the pattern or wood is rough, then thin tape does not hold. Use thicker tape or double thichness.
Keith Newton----Little Rock, Arkansas
Most makers have several kinds for different purposes. I like the cloth core best whether 3M or ACE. Stay away from the thin plastic core, it is worthless.
For a lot of parts, I like to make the template and blanks a bit longer, so I can use screws, in an area which will be cut off of the finished part.
Howard Acheson
I use the Duck Tape brand of cloth double faced carpet tape. I've seen it in a number of places. Most recently I bought some in Home Depot in the carpet section.
ULINE
Paul woolson
Do yourselves a favor and look on uline.com for their brand of double sided masking tape. I was turned on to it by a guy that uses it to tape bowl blanks on to the chuck. I thought he was nuts but then saw it first hand and it's amazing how it will hold. If it's clamped on, it will be VERY hard to get it apart. (you'll need a pallet knife for this) Or a press fit will make it removable.
I used to use carpet tape but the "goo" of it really bothered me. This uline tape has none of that, and it's very thin so there's no deflection between the pieces you are working on.
