Design "opportunity"?
A friend of mine is one of the most "frugal" people I know. She found the bits of a broken mirror frame.
It is nice carving. I'm thinking about incorporating the top (rounded part and carving) into the top of bookcase. I'm thinking about putting the other carving at the base of the bookcase. I can then give her the bookcase.
I wanted to make the bookcase about 48" or so tall (with carving). That would make it about 30" wide for a reasonable proportion. I was figuring on three shelves, possibly four.
I was going to leave the larger caving and rounded portion intact - possible taking off the backing board and using a new board. I want to use the bottom carving - but I may just put it on a new board.
The height of the carving and rounded piece is about 6". The height of the the bottom piece is about 5.5" and about 2" for the carving. The overall width of the pieces is about 32" or so.
Thoughts? Opinions? Should I make it a shorter bookcase? A taller one?
TIA
Re: Design "opportunity"?
My guess
paul in AZ
This obviously came from a very large picture frame. As such that large top moulding was well above eye level.
Putting it at 48" so you look down at it may come out looking strange and be proportionally too large for a shortish bookcase. I'd favor thinking about putting it atop a taller bookcase so it was at eye level or a bit above.
If you have a tall bookcase at home how about resting it on some partially pulled out books at various heights to see what appeals?
Mirror frame for dresser.
I also have the side pieces.
AZ in Colorado Springs
If the height of the pieces is a bit overpowering, perhaps a book case about 24"-30" tall with a couple of shelves, but it hangs on a wall with the top edge about 72"-80" above the floor. Then people still look up toward the carvings.
paul in AZ
Carrying this thought a bit further... instead of a hanging bookcase how about a wall mounted display case for curios? Lighter weight and easier to support than a case full of books. Does she collect curios?
Want to reuse...
as I said, she's "frugal". It's good looking oak - I really want to reuse it.
