Refinishing a Shuffleboard Table
Bill Lordan, Auburn NH
Our club has an old shuffleboard table that desperately needs to be refinished. Knowing that I am a hobbyist woodworker and having no luck finding someone else to do the job, the officers of the club - of which I am one - have approached me to see if I could do the work. The table is a beautiful old hard maple table - well over 20 ft in length - and it certainly warrants the work. My first concern is there more to refinishing a shuffleboard table than the obvious sanding, sealing, numbering, topcoating and waxing that I should be aware of? What type of finish would you recommend and what pitfalls do you forsee in the process.
My second and much deeper concern is getting paid for the job. As an officer of the club with a brother on the board of director I can see many of our members seeing my taking on this job for pay as pure nepotism. I refuse to cast myself or my brother in this light - but I do want to see the table getting done - so I am seriously considering donating my time and charging the club for only materials and expenses. Is this the thought process of a rational man? The phrase "No good deed goes unpunished" haunts my thoughts. What do you think? Please feel free to be brutally honest.
Thanks for your response.
Bill Lordan
Re: Refinishing a Shuffleboard Table
Bill Tindall
1. I don't even know what a shuffle board is but I would think that the best "floor finish" would be appropriate. I have this vision of something sliding on the surface, so it must be smooth. Unless you are experienced at finishing, getting a surface smooth could be a problem. This doesn't sound like something to be learning refinishing on. Is there any place on earth that doesn't have a refinishing shop within reasonable driving distance?
2. Of course you donate the time, not the materials.
Bill,
On the conflict of interest issue, you can poll the members to see if anyone else is qualified to do the job, if nobody steps up, announce that you've been "elected", and go from there.
The sanding, sealing etm. is pretty straightforward stuff. The big question is the "wear" coating. Time was, you had two option "Gym-seal" or oil-based polyurethane. If you had the equipment, there are new coatings (UV cures or 2-part polyesters) that would out-do most anything, but they're all industrial/factory products. I would, therefore, look to the floor refinishing products arena. There you will find the best wear finishes.
I would recommend the Bona Mega line of coatings as I have personal experience with the stuff. They are ($60/gal) waterborne crosslinked reactive floor finishes that perform beautifully on wood floors. You can apply them by "mop" or by HVLP (with a larger gun tip) spray. Use a compatible sealer like General waterborne Sanding Sealer. Wait 2 hours and sand lightly to remove any raised grain. Apply your lines and numbers. Then apply 4 coats of Bona Mega Gloss about 4 hours apart. Let cure for a full 7 days, then rub out with a superfine synthetic buffing pad, and apply a coat of Tre-wax and polish.
Caution members not to walk on the table lest they go handle-over-spout as it will be a slick surface.
Gary Smyth
Hummm. Even though you are now committed, be prepared if you do not come out ahead on this one. Forevermore the club �brother� who loses the game will complain that the table is not as it once was. True or not, it will be too fast, too slow, has a groove in the top, whatever! They won't aim the comment directly, but be aware. If you have a thick skin you�ll be fine. This is work, big work (are you doing it in house?) but if you charge over and above cost you will not get credit for the amount of work and perhaps, worse. Still, new, these sell for $3,000 - $6000 for a 12 foot table. If you can refinish for under $1000.00 who can complain? They'll all be playing the same table after all. That said, contact the manufacturer. They will advise how to refurbish. Should they fail, a bowling alley refinisher can provide the info. For Shuffleboard, Hudson makes nice shuffleboard tables (714-988-0001 (CA)), so does McClure (1-800-565-0977 (MI)), Champion, the table I know does too, (817-284-3499 (TX)). No matter what, you ought to have a several stencils made for the painting with custom color paint silk screened on, so that there is no paint lip anywhere. And while you�re at it, at minimal extra cost you can customize the refinished table to the club with a centered stencil logo or other artwork like they do with a basketball jump circle. That should get you started. I figure with manufacturer assistance you can refinish it with the right materials but if you also dazzle em with custom graphics you could come out a winner. I'm assuming that what you are talking about is similar to the picture.
Howard Acheson
The first and most difficult step is to be sure the table is absolutely flat across and lengthwise. Older, well-used tables can be problematic in this area.
Getting It Flat
If that is a problem, I'd use shooters on each side, and then drag a straight edge to "screed" several cups-worth of Mirror Coat epoxy down the length to use that as the starting surface. If the edges of the playing surface aren't worn, you could probably dispense with the shooters. You could also apply the graphics first and then "embed" them under the epoxy coat.
Re: Getting It Flat
Hello Guys;
Thanks for all the great responses. I especially love the idea of the stencil for the club logo and the floor finishing products sound like it will be a perfect fit for this situation. I still haven't entirely committed myself -especially as it was pointed out, this is a no win situation because some will hate what I have done regardless if it is good or bad - but I am thick skinned and I am leaning towards doing the job. I'll keep you posted.
Thanks again for your thoughtful responses
Bill Lordan
Auburn, NH
