Any caning experts out there?
james runchey
After searching in vain for someone to recane a couple of antique dining room chair seats. I decided to do it myself. Wrong move. I just came in from the workshop after struggling 3 hours removing the old spline. One down, one to go. Actually there is a lot of residue left in the groove and I'm looking for an easy fix to clear this out. I read that you could put hot water and vinegar in the groove and let it soak a while, but I.m afraid of messing up the varnish. Any ideas,tips? Anyone done this?
Re: Any caning experts out there?
Keith Newton----Little Rock, Arkansas
Most glue will soften with heat, so I would try something like a soldering iron, or wood burning tool, or even torch a bolt. I'm just offering suggestions that might work, that I have not tried. But bending a screw or bolt, heating the threaded end, and using that to pull out the glue seems appealing. I would like to hear if it works. ha.
Phil Joines
How about making a cleaning tool from an Allen wrench?
james runchey
I did make a couple of cleaning tools. one from an old screwdriver and one ground from a piece of flat stock. Both leaved a bit yo be desired. That old hide glue is hard as a rock. I think I will try heat of somekind.
One thing
Dan Donaldson
When you glue it back in, use hide glue again or the next (and there will be a next) time repairs are necessary, it will be a lot harder to do.
Jim Hoeller
I have recaned several chairs using sheet stock and splines. Cleaning the groove is a pain especially if the last person to recane the chair used too much glue. I ground a chisel down to just narrower than the groove and CAREFULLY scrape out the old glue. I keep the chisel sharp and take my time.
