Multimaster for grout - good or bad idea?
Tim Greif - West of Chicago
LOML is interested in regrouting some of the bath areas, wall and floors. How well does the Multimaster type tool do at removing the old grout? I've never used one and I'm concerned that it may damage the tile. I've used an angle grinder very carefully to do this but it takes some concentration to avoid damaging tile. Plus it's adusty mess. Anybody have a better way?
Re: Multimaster for grout - good or bad idea?
Stuart Johnson
I used the Dremel version when I redid the shower. It works very well and is fast. You do need to be very careful though because it will cut the tile just about as fast as the grout. The shape of the grout blade helps prevent accidents.
Mark Nowicki
I tried using my Dremel version of that tool and it was useless. You would need the patience of Job and countless blades. A rotary type tool (RotoZip or Dremel) would be my choice.
I tried my battery powered Dremel which worked much faster than the multitool, but the battery capacity is too small for any serious work.
Mark
Stuart Johnson
Mark, Interesting two of us have used the Dremel with different results. Did you use the actual grout blade? I had previously used a regular Dremel with the round grout bit and didn't care for it one bit. I don't have any experience the the Roto-Zip.
Mark Nowicki
Yes, I did.
I was changing a bathroom window, and had to remove about 30" of grout. I got about 4" done in 15 minutes. The best tool for that job turned out to be a hook knife with a carbide tip.
Both my Dremels fall into "tools I regret buying" category.
Regards
Mark
Stuart Johnson
Are you talking about a silicone type grout or the type between tiles? I can sure see how a window or tub type grout would be a problem.
Mark Nowicki
The between tiles type.
I don't know what "silicone type grout" is.
Mark
Stuart Johnson
Me neither.... Sorry, when you said around a window I was thinking caulk rather than grout.
matt overton
The Multimaster does work well for grout removal. It is still time consuming, but works as intended with minimal damage.
