A55 Smoothing Plane
glueing wood to laminate
ronald rimmer
I'm putting new laminate over old on counter top and would like to trim the edges with red oak which needs to be glued to the old laminate on the edges. Can I use wood glue or do I need to use another type of glue?
Ronald Rimmer
Re: glueing wood to laminate
Contact cement
If you don't intend to remove the laminate edgebanding from the existing top, my advice is to rough up the surface of the edgebanding with a coarse grit of sandpaper and then contact cement your new edging on. This isn't the greatest way to do it, as you'll probably end up with some gaps between the oak and the surface laminate, and the seam might want to creep open over time. A better way would be to remove the existing edgebanding, rout a straight new edge down to bare wood or plywood, then glue the new edge on with a waterproof wood glue like Titebond 3. Trouble with that approach is that, if you're doing this in place, it could be tricky to clamp the edging tight unless you have a lot of edge clamps.
Your call.
If you rough up the edging with a heavy grit (you must do this on the top as well), epoxy might make a satisfactory bond for the wood to the old laminate. Nothing else will do IME. I'd strongly suggest that you rip off the edging, scrap and remove the contact cement residue to get to raw substrate, and then use a good PVA to put on your oak.
Question: How/when will you put on the new top material? If you apply your oak, apply your top surface over it, and then cut back with a router to expose the oak edging, you'll get a much nicer and more durable edge.
ronald rimmer
Thanks guys,
not exactly what I wanted to hear.I suppose I'll use contact since I have the top laminate already glued down .
Ronald Rimmer
I would not do it that way.
Keith Newton----Little Rock, Arkansas
You need to remove the old edge lam. You have no way of knowing how good it is stuck without taking it loose. If you go over it, I would use finish nails, or screws, and maybe a silicone caulk between them at the top. You can use masking tape on both parts, then wipe away the squeeze out.
If you don't fill the grain of that red oak, water will get into the open pores, and wreck the finish, around the sink or other wet areas.
Dave Bair, Eaton Rapids, MI
You might try routing a groove in the laminate and adding a tongue (or loose tongue) to the edging for a strong glue-up or just use your biscuit joiner (it'll make a surprisingly strong joint if you use 3 biscuits/foot of trim). I've done both and they're still holding 3 and 4 years later, respectively. You just have to be careful to get your heights right; too low can't be fixed, too high is tough to correct without damaging the laminate. Make sure to dry fit this fairly demanding glue-up.
