THE WOODRAT IS BACK!
OT- Humidifiers
OT- Humidifiers
OT- Humidifiers
Thomas Norton
Since changing to hot water heat our house is in need of more humidity.
What kind of stand alone units are you guys using?
Thanks!
Re: OT- Humidifiers
Re: OT- Humidifiers
Mark Nowicki
Our stand alone humidifier is a drying rack in front of a fireplace. With four adults and two teens there is enough laundry to make the windows sweat.
Cooking lots of soups also helps.
If you live in hockey country you could offer to do laundry for a team.
Mark
Re: OT- Humidifiers
Re: OT- Humidifiers
Paul Leuba
This year we are burning a wood stove to minimize our oil consumption. The Honeywell Model HCM 3060 does a good job of holding the humidity in the range of 35 - 40% when the temperature stays above 25 degrees F. Below that temp, the humidity drops to the 30% range. This seems acceptable to us and is within the recommended range printed on the controls for our furnace humidifier. The unit has a fan that I find a little loud.
The unit is specified by the manufacturer as a 6 gallon per day unit, but I believe 3 - 4 gallons is a more realistic indicator of its performance.
Paul in Hunt Valley, MD
Re: OT- Humidifiers
Re: OT- Humidifiers
We got a Sunbeam cool mist humidifier earlier this season. We are both breathing better. It seems to work. The one we got is really for a room, so I can't say anything about a whole house humidifier.
Re: OT- Humidifiers
Re: OT- Humidifiers
FredD
We have run a Bemis for years in the Winter time , we have slab heat which has heated water from a wood fired boiler , in addition to a 95+ gas fired Furnace.
This dries the air until without the Bemis I would go crazy with dry skin itch in the Winter time.
This more is 1200 and is rated for a thousand sq. ft. and I generally nedd to fill the removable tank twice in 24 hours.
I get about five or six yearts use out of the each unit and have to change the filter twice by Spring.
FredD
Re: OT- Humidifiers
Re: OT- Humidifiers
Robert R. Clough
Yes, we have one of those also. They do seem to work and reasonably well. Of course we should have two if them.
