200+ woodworking book reviews
got a new PC 2.25 HP router for dovetail
Keith Newton----Little Rock, Arkansas
I got this router just for leaving set up for dovetailing, but it came with a base that doesn't have a way to attach the guide bushings. What do I need to make it work? Model 8902
Re: got a new PC 2.25 HP router for dovetail
Frustrating evening. Went to Sears which is the closest tool store, to see if they might have replacement bases. They had a box with 6 in it, none of which would take PC guide bushings, yet all the ten or more routers on the shelves had a base made for PC guide bushings.
Came back to the shop and found a scrap of 1/4" polycarbonate, then made one from it. It turned out fine, but they always take a lot longer than it seems like it should.
Usually the SKU number of the tool reflects all the various assembled components. Either you bought a model you didn't want, or they somehow packaged it incorrectly. It should be pretty easy to order the base you need, but now you've made one so problem solved.
Regardless of whose base you're using, be sure the template bushing is concentric with the collet, or else you'll run into some real accuracy problems when template routing.
David Yoho
Keith, I have that exact model mounted in my table. I also have three 690 series and one that stays setup for use with my Leigh jig. Although you've already fabricated your own base plate, the PC model # 42186 fits both the 690 and 890 series should you need it. What Ellis mentioned about the hole being centered, as you're probably aware, does make a difference in how the joint fits.
Thanks Ellis and David.
I was aware that there could be problems if I didn't get it centered, but I guess my method was good enough, because I just checked it with a dial caliper, and was happy to find it was less than one thousandth.
One little thing that I found which was handy, was that the outer ring of the PC bushings is the same size as the cup drill for most of the euro hinges. I didn't have a drill to match the threads though, so I just free-hand routed that portion, confident that the other part would take care of alignment.
Once I had the bushing mounted in my new base, I used the depth plunger on the end of my dial-caliper to center the base that came with the router. Then clamped them together to use as a template guide to drill the screw holes.
I was really surprised that it came out this good. May be just a case of the "blind hog, scoring another acorn" though. ha
