Undercutting door jambs for Tile Question
Putting quarry tile in the bathrooms in the house I bought at foreclosure. How High would you cut them? I have put Ditra on the floor and the tile is about 5/16" or 3/8" thick. It calls for a 1/4" notched trowel for the thin set. How much does the thin set raise the tile? How much would you allow?
Re: Undercutting door jambs for Tile Question
Mark Nowicki
Take a piece of Ditra, place a tile on top, put next to door jamb, add 1/4'' (eyeball or use micrometer), draw a line, cut jamb at line.
Test fit, if too tight cut again, if too loose tear down house and re-built.
If this is supposed to be a math question, I need to know the thickness of the Ditra.
Mark
Mark, The ditra is about an 1/8" but It is already installed. So what I need to know is how much thickness does the thinset add to the tile. The tiles are 12" square and about 5/16" thick. I have the tiles.
Jason Roehl in Lafayette, IN
How I would do it.
Lay the rest of the tile first, leave doorjambs for last. You should have at least one or two tiles in the doorway area. Then, take a scrap piece of tile, small enough to fit between the laid tile and the doorjamb, flip it over and add something to shim it up to the same finished height as the tile around it, then scribe a cut line on the jamb with a sharp (utility or marking) knife. How you cut it depends on the tools you have on hand.
Jason
duh! did not think of....
turning the tile over. I have the Bosch version of the Fein Multi Tool and cut one by taping a piece of cardboard onto a piece of tile. That left about a 1/16" of clearance. Looked at it and decided I should ask. I don't want to wedge the tiles in too tight.
Re: How I would do it.
Joseph Mulherin, Sr
Barry, Mark and Jason are correct in what they have said. Lay the tile next to the door and add 1/4' to 3/8" room above the tile for the cut. Use your Multimaster to make the cut. The thinset should not raise the tile any way....
the grooves on the underside will determine how much thinset will be used for adhesion to the floor...Ditra. Use a long-time setting thinset so you do not end up with a bucket of hard mud....which happened to me when I started my project. I finally went with the already prepared thinset in the gallon buskets.
'nother way
paul in AZ
My house has tile added by several different people over the years. I just looked at the jambs and baseboards.
The tile runs to about 1/4" of the baseboards and there is a grout line to fill the gap.
The jambs were cut reasonably close but with 1/8" to as much as 3/16" of air. This was filled in with grout and looks fine. Nobody would ever notice that detail unless specifically looking for it anyway.
If you want to be really picky why not go ahead with the tiling until you get close to the jamb; use a straight edge to project the floor level and mark where the tile comes to then cut there.
Another quick and dirty way if you are not sure is to make your closest guess and cut the jamb at a 45 degree angle. If too little you could chisel away a bit and if too much it would look OK when grouted.
Ps....
The Multi tool is not jamb saw, but it will take me less time to saw off the three jambs than it would to drive to the rental shop to rent one. I don't cut enough jambs to justify owning a jamb saw.
I bought the multi tool on a whim, it was on the close-out table at Lowes for about half price. I quickly found out the charger was defective. I called Bosch and they insisted they should send me a new battery to try. That did not work, so they sent me a new charger. (Now I ahve three batteries) I am astounded at how many things I find I can do with the tool. One of my happier accidental impulse purchases.
Concur, except for the part about tearing down the house. You need only tear out that room and all adjacent rooms.
When I undercut the jambs in our kitchen years ago, I set a section of the new flooring down with whatever underlayment I used - basically everything that was going to create thickness - , rested one of my less favorite handsaws on it, and used the stack of stuff as a "fence" to guide the saw. This is similar to other suggestions, but, since I used a handsaw, was done before any flooring was laid to give me working room.
When we redid the kitchen a couple of years ago, my contractor son did the same thing except he used a Japanese saw.
Neither one of us owns a Multimaster; don't know if it's quicker or slower than a handsaw.
It's probably better to leave a little more than a little less room, for a couple of reasons. First, it's easier to slide tile under with room to spare than have it not go under while you're there, thinset mixed and heading toward hard, you busy cursing the gods, children crying in the other room because you're yelling, dog hiding under the bed, etc. Second (this is me being obsessive but also experienced with old houses), it's better if there's a little gap anywhere end grain is near a bathroom floor, to avoid water soaking up to rot.
I'd use a flexible, paintable caulk rather than grout, because I think it would be better at staying in place and not gapping; but both should work.
3rd Way
Take a 4.5" mini grinder.
Using a sanding backer kit, put the flair nut on first with the large diameter facing in, then put on a 36 grit disk with the grit side reversed (facing up), then back that up with the hard rubber support disc also reversed, and, lastly, run on the flange nut used for grinding wheels to secure it all.
This will very quickly remove excess jam material in a very controlled way as the abrasive will cut as it all slides in under the jamb. Mark a line for your tile and grind up to it.
FredD
Contrary to what you have heard here , the closer the fit of the Jamb to the tile, the better it looks and says a workman did it.
Having said that, put a tile and a piece of your underlayment on the Ditra and cut off with a 8 point handsaw , saves time , looks right and you should have a 3/16ths gap or less to work with.
The Thinset is not a problem for height , unless you let it set up before the tile is installed , which makes a poor job regardless of how you cut the Jamb.
Regarding keeping the end of the jamb and casing off the floor to avoid floods in the Bath is ridiculous. you wouldn't install Base that way , would you ?
FredD
Before power tools
Galen Vetterick
I used a reversible offset dovetail saw to trim five doorways in my lower hall when changing from carpet to wood flooring. Let me cut from left or right and kept my knuckles off the floor. I used a scrap piece of flooring to rest the blade on to start the cut. Left a good cut on the oak trim so needed no touchup.
If using power I would put tape on the surface to insure a spliter free cut.
I agree, Fred, about the size of the gap. I realized, in looking at my own response, that I'd implied a large gap is a good thing; in fact, the 3/16" gap you suggest is about what I'm aim for, too.
And I think a handsaw is a superior tool for the application than one of the multimaster type tools, because it will leave a straight line, which is far less visible (regardless of gap) than an irregular one.
I can't dispute your judgments from your years of experience on far more houses than my experience, which is limited to our 1895 house and some of the houses our son has worked on. The bathrooms and kitchen in this house were remodeled somewhere around the year of my birth (1948), and were still more or less intact when we moved into the place in 1973; and we did encounter some up-from-the-floor rot on door trim. Casings/jamb expose end grain; baseboard does not. Still, my experience with that - and our own tendency to remodel infrequently - has led to the somewhat obsessive (I'll acknowledge it) approach to this kind of detail on my part.
And the drafts that blew through this house when we moved in have made me equally obsessive about controlling air infiltration/exfiltration.
(There is a certain tendency to obsessiveness in my family; I guess better to express it this way than some other ways...)
Realistically, the likelihood that the house Barry's working on will stay just as it will be when he's done remodeling for as long as our house did is very, very low; so this isn't a critical issue.
Re: Undercutting door jambs for Tile Question *LINK*
Hoa in Alameda
I use this "PullSaw" to cut the door jams (link at the end of this post).
>> "Regarding keeping the end of the jamb and casing off the floor to avoid floods in the Bath is ridiculous. you wouldn't install Base that way , would you ?"
Of course I don't install baseboards off the floor.
But I prime all sides of the base, and give the bottom side a bead of silicone caulk.
Shark Corp 10-2440 Fine Cut Saw
Well, OOPS....
I put a piece of tile down on top of the ditra. I taped a piece of cardboard onto the tile to add a little thickness and to protect the blade from the tile and visa-versa.
It left about a 1/16" space. Just did not look like enough so I switched to a little wood shim and left about a fat 1/8".
Put the tile in and appears the facings shrank and contracted toward the ceiling. Apparently that notched trowel combined with the waffle pattern on the back of the tile eliminates any added thickness.
Oh well! Caulk is my friend. This is what experience is all about. They will be better in the next house.
Re: Well, OOPS....
Mark Nowicki
Barry, please don't tell me it took you TWENTY FIVE hours to trim one door jamb.
Mark
I have a feeling Barry may have a day job too...
Re: Well, OOPS....
No, not 25 hours, closer to 25 minutes. I am working on a house I bought at foreclosure for my son. There are two bath rooms with three doors amongst the two. I cut one off, decided it was too low (should have left it) and then cut it again, and then cut the rest of them. Spent the rest of the day installing the tile and a room of vinyl floor. Going today to grout the floor, then on to putting tile around the tubs. And base board. And paint. And rehang the doors. And install the hardware. And .....
