glue tear out
glue tear out
glue tear out
Jerry Gibbs
recently glued up a panel out of honduran mahogany. used titebond 1. when i went to scrap off the glue beads from the joints, the glue pulled out chips of wood. any advice other than sanding off the glue rather than scraping?
Re: glue tear out
Re: glue tear out
steve mackay
Sanding is the only thing I've found. Any blade / iron / cutter I've tried will "grab". As any glue bottle claims, it is stronger than the wood. If it "grabs" the glue, wood is sure to follow.
Re: glue tear out
Moses Yoder
Re: glue tear out
Moses Yoder
The glue should be removed about 3 or 4 hours after clamping. Then it is soft enough to remove easily. If you do leave something glued up overnight make sure you are scraping with the grain and not against the grain; you can look at the edge of a board and see which way the grain slants. You should follow the upward direction of the grain slant.
Re: glue tear out
Try this
Wait about 45 minutes to an hour, then slice it off with a paring chisel, pointed across the glue line and using a sideways slicing cut parallel to the glue line. Works for me. If you let it dry too hard, you'll have to make a judgment call as to whether a scraper is going to result in tearout or not, based on how flaky the wood is. Be particularly careful if it is veneer. If you're worried about it, take your time and scrape lightly. If you own a cabinet scraper, try that first. I don't recommend sanding if you can avoid it. Fine sandpaper clogs quickly, and coarse paper tears up the wood surface.
Re: glue tear out
Re: glue tear out
Keith Newton----Little Rock, Arkansas
I have not tried it for this, but I think you should be able to use a heat-gun to soften the glue. I think the trick would then be just how fast to travel, and what blade to work with.
I would start with a chisel with a face bevel, so you can use the main bevel up, without much risk of the flat side digging as you push it in under the heat-gun tip while you move them along.
Re: glue tear out
common problem
Bill Tindall
1. Don't wait till the glue is a rock before scraping.
2. I keep an old block plane for glue bump removal.
3. When I took a class at Headleys we were chastised if we used so much glue as to get bumps. I have mended my ways and now apply glue with small paint brush, applying a thin layer to both surfaces such that just a tiny amount squeezes out.
Some advocate wiping off when it is still wet but it seems to me that risks getting glue into the wood where it will affect staining/finishing.
Re: glue tear out
Re: glue tear out
AZ in Colorado Springs
Would the heat from the heat gun affect the glue in the joint? I don't know, but it would seem likely that if there is so much excess glue that a heat gun is required to soften it, then where else is that heat going?
As Bill recommended, try use just enough glue that a line of small beads appears when you tighten the clamps. Try to avoid so much squeeze out that it "flows" onto the wood. I wait about 30 minutes then slice off the row of congealed beads with a putty knife.
Re: glue tear out
a solution
Jerry Gibbs
Glued up another panel. Removed glue while rubbery. Trick for me was to plan ahead so that clamps did not get in way. Jerry
Re: glue tear out
Clamps should not be a porblem
Bill Tindall
Clamps can be removed from a good joint in as little as 30 min (under best conditions) and certainly under any conditions long before the glue blobs harden, a process that takes many times longer then curing the thin joint layer of glue.
