Design question - trestle table base *LINK*
Henry (Raleigh, NC)
Short version: How would you attach the table top of a large table to 4 posts/legs inset from the corners in a trestle type design?
Much longer version:
I have a large table I am building. The top will be 10' long x 40" wide x 2" thick. Heartwood pine material - ready to glue up right now.
My question relates to the base design and attachment of the top. This link shows a similar design: link is below.
The base will be similar to what's pictured there:
- The stretcher bar will be large, flat, and low to the ground.
- The base of the legs will have the same orientation and relative size as the picture (i.e. larger than vertical pieces and be one beam perpendicular to the long side of the table).
The change from the picture is in the vertical pieces. I have 4 posts that match kitchen island posts that are already in the house (same supplier - Osborne Wood products). These turned posts have a 6"x6" square region (i.e. unturned) at both the bottom and the top of the posts. So I plan to mortise these posts into the base and then add lag screws through the bottom beam.
The base beams are 3.5" thick and 8" wide. I plan to mortise/excavate a 6" square about 1" to 1.5" deep to sink the two posts as tenons into each base. If I mortise a full 6" wide, a 1" strip of the beam is left along each side of the mortise (because base beam is 8" wide). I think that is hefty enough, but I could cut down the tenon to a square 5" on a side or less. In addition to mortising, I plan to drive lag bolts up through the beam into the posts - I know this is into end grain of the laminated posts, but I don't see how else to do this.
I am certainly open to suggestions for base construction, but my most significant question comes with attachment of the top.
I was planning to mortise each post into the top; remember the top is a full 2" thick and so I figure I can mortise 0.5 - 0.75 inches without any problem. This will register the top of the posts in the length direction, but I am concerned that I do not have enough support for the sides of the table this way. These posts are 6" square, and they will be separated by a 9-10" gap, so the outside edges of the posts will be about 22" apart. This leaves a 9" overhang from the edge of the post to the edge of the table. Is that too much? This also does not have any direct mechanical attachment of base and top, I need to get some screws in there somewhere.
Also, the design as described so far does not account for seasonal movement/expansion/contraction of the table top width. My sense is that I should use a 2x2 or 1x3 rail or stretcher connecting the top of the posts across the table width (out of view; there is no table skirt). The rail would be screwed into the side of the posts, and have slots for screws into the table top.
Any critique of my plans? How would you attach the table top to 4 posts inset form the corners in a trestle type design?
I am not certain that mortising the posts into the top has any value if I use the cross rails. Do you think it does?
Henry W
hwynands@ieee.org
Trestle table - Restoration Hardware
Re: Design question - trestle table base *LINK*
Dan Donaldson
I would run a Stringer between the posts across the top. If you did not want them to show, then inset them into the top of the legs. This would give you a flat surface that you could run screws through to fasten the top and they could be in slots to allow for movement. The image I am attaching is looking down at the top of the legs. The cross pieces could be inlet into the tops level with the top surface then glued and screwed. The top could then be bolted to the cross piece.
Henry (Raleigh, NC)
I like that idea - fit the cross piece into the top of the posts rather than into the top itself.
- Why would I not extend that cross piece past the posts (beyond the outside edges), assuming it can still stay relatively out of sight? Would that not provide more side to side stability for the top?
Henry W
Clint Searl
I Agree
Clint Searl
The legs/posts should be connected across the width of the table, and mortising them into the top will prevent movement without additional mechanical attachment. Also, at 120+ pounds the top won't tip laterally or longitudinally. The top of the the table, below, floats on 1 1/2" diameter levelers that sit loose in shallow mortises, with no tendency to tip.
Clint
AZ in Colorado Springs
To avoid screwing lag bolts into end grain, you could use threaded inserts and bolts. You could use threaded inserts to secure the top as well.
Keith Newton----Little Rock, Arkansas
Henry, I like to clamp the top boards together upside down on a workbench, then run the router across with a straight cutter, then follow with a T cutter.
Then I wax the rails and slots before gluing the top boards together. If the slot is ~ 1/2" longer than the rails, the top can move freely, but can't cup.
You can make the T rails taller in the middle, thinning toward the outside. One on each side of your legs, gives you an easy attachment to the legs through these T-rails.
In the link to the photos. It is a good thing they used a breadboard ends on that table, because they cut into the arm supports too far.
Dan Donaldson
It would be rigid enough that extending would probably not make much difference on a 2" thick top, but should not be a problem in any case. I suggested inletting them so they would not be visible more like it would look if you mortised them in. If visibility is not a problem, they would not even need to be inset into the legs.
