why I prefer to veneer on MDF
Thomas S Stockton
Hi all
Recently there was a post about mdf vs ply. I usually veneer onto mdf since it has a habit of staying flatter. I will veneer onto ply wood if strength is an issue or I feel it will give better results. Here are the reults of what plywood will do when it wants to move, I have two of these tops this one in claro walnut and a second in pommele sapele both are unusable, both had plywood cores. Should have used mdf in this case. these have a 5/16" twist in them
The cores were baltic birch from my hardwood dealer, the real thing not an asian imitation.
they started off flat before pressing and came out of the press flat.
Both sides were veneered and finished the same.
Moral of the story use the correct material for the job and fixing stuff is much harder then doing it right the first time.
Tom
Re: why I prefer to veneer on MDF
Jesse Cloud
Ouch! That's a heartbreaker! The veneer is lovely, what a bummer.
Thanks for sharing.
I just made a jig out of some crappy plywood, better get some use out of it before it does the twist!
Bill Tindall
There was an architectural panel manufacturing plant nearby some years ago. They laid up veneer on either fir plywood or a very heavy, dense flake-board. I have some 40 year old sheets from them and all are still flat. The moral of the story is properly dried material stays flat. I bought some China "baltic birch" once and it was 18% MC after a week of storage. Warped into a potato chip. And I have seen other Baltic birch- like material that stayed flat. I guess the other moral of the story is today's plywood is a crap shoot.
It begs the question...
... When will plywood "give you better results" than MDF? For me, it usually had to do with moisture concerns in the environment the piece would live in or whether the panel was constrained by an assembly. I'm curious as to what sorts of situations you deem to be okay for plywood cores?
On another note, Tom, your work is so refined that I would say it speaks highly of the use of MDF in fine furniture.
