Saunas
mark a
Has anyone ever made a homemade Sauna? I thought about buying one but thought it would be really nice to build my own. Didn't know how hard it would be!
ps. I didn't check all of the archives to see if this subject was in here ms.
Saunas
mark a
Re: Saunas
Frank Orfanello
Mark,
I built one about 4 years ago. It's about 5X10, cedar siding with two benches. The walls are just 2x4's 16" OC insulated, the floor is raised so that i could put rigid foam insulation down.
The heater and controls I got mail order from a company in California. I'm not sure I remember the name but I'll see if I can dig it up.
I use it pretty frequently and love it.
Re: Saunas
Tom Dunlap
A FRIEND of mine who is a carpenter has built a couple. I've helped him on both. A couple of things that are key is to pay attention to the vapor barrier and insulate well.
don't make it too big. If it's too big and tall, you'll get it warm but have a hard time getting it HOT! Keep it low.
Watch the choice of wood for the walls and seats. There are some species that are better than others. Knots in the wood can become hot spots and lead to 'burns'...ouch! Don't have exposed nail heads. Either set the nails or secure bench wood from underneath.
enjoy!!!
Re: Saunas
Keith Newton----Little Rock, Arkansas
I built a commercial one about 35 years ago, so I don't remember much that would help, except that I used Redwood, and there was a lot of shrinkage.
I built the door with 2x6's , splines, and Z bracing. Good thing I used wide splines, since the gaps were pretty wide after everything dried down to 0% MC, so keep the shrinkage in mind.
Also, I don't know what materials you plan to use, but I have been impressed with Solarboard, a OSB with foil for roof decking. If you plan to use all solid for the inside, this may make a good second layer to nail it to.
Of course, there would be a different set of design problems for one which gets left on full time relative to a smaller one which you turn on a bit before you get in it. Just don't make it tight enough to smother yourself. %\],,,,,,,,,k
Re: Saunas
Joseph Mulherin, Sr
Mark, I Googled "sauna plans" and came up with some free plans you could get
and use in your project:
www.greatsaunaplans.com/plans.sauna_layout.cfm; and... www.saunaplanning.com
Hope this helps
