OT cutting Ceramic tile with Multimaster?
I have the Bosch version of the Fein Multimaster. It has a carbide blade with grit around the edges that says its a grout removal blade. will this tool with this blade or any other blade efficiently cut tile? I have been watching YouTube for about an hour and All I can find is a reference that it will damage the tile.
I am getting ready to install two bathrooms worth of floor tile and tub surrounds. Trying to figure out what cutting tools to buy or rent.
Re: OT cutting Ceramic tile with Multimaster?
Nelson
Need to buy or rent a tile saw,the water cooled type.Tried to cut a small piece once with my Multimaster and no luck. A tile saw is a lot faster anyway.
Re: I agree
matt overton
Nat Robison
No experience with a multimaster on tile but as said earlier, I think you'd be opening yourself up to a ton of headache trying to approach a few rooms worth of tile without a water-cooled, diamond blade saw. As long as your pattern isn't too ornate, you can lay most of the field tile and then rent a saw for a day to make all the cuts. Around here, a saw rents for about $55/day from HD.
Joseph Mulherin, Sr
I agree to buying or renting a tile wetsaw. I bought a small one at Lowes when I did my tileing...350 ceramic tiles...with about 50 cuts to be made. Layout all the tiles to get them situated evenly, then butter up the floor and tiles with the mortar and install. Let dry and setup totally for at least a day. Then measure your cuts for the other tiles, place a number on tape on each space for rememberance of where they go, setup you wetsaw and do all the cuts...numbering them also the same....then go and install as needed. Wait at least a day before qrouting.
For a suggestion on the curve on the tub apron...lay down a couple pieces of paper taped together next to tile already installed....trace the curve with a pencil or Sharpie...use this pattern to mark you tiles for cutting.
John Veerkamp
If you don't have excessive amount of cuts, an angle grinder with a diamond blade works just fine. I did a tile shower 3x5 that only took a few hours all together. The blades cost less than $20 . If you already have an angle grinder You can remove the time pressure and save money to boot.
Bill Tindall
When we had tile installed the straight runs were scored and broken and the cutouts were done with an angle grinder and diamond blade. When we ahd rock counter tops installed they cut everything that needed it with an angl egrinder and diamond blade.
FredD
Professional Tile Setters use Wet saws with a diamond blade , rent one from a tool rental , they mike the blade going and coming and the wear is what you pay for.
FredD
Howard Norman
Barry, I have a wet tile saw that I use for most tile cuts. However I also have a diamond wheel for an angle grinder that works quite well also. The wet saw yields straighter and cleaner cuts. My first tile job, about 30 years ago now, was with an abrasive wheel mounted on a radial arm saw. Talk about dust!! It got the job done but I would not recommend that technique to anyone. The job was slate tile for a fireplace hearth.
John E in SC
I did several rooms in my house using a "score and snap" tile cutter, and a diamond saw blade on my rotozip (similar to using an angle grinder, but has variable speed and I think a bit easier to control.) Yeah, it makes a lot of dust, but the one time I rented a wet saw, that made a huge mess too (just a wet one!). I don't remember the cost exactly, but I'm betting a rotozip plus the saw blade attachment and diamond blade wouldn't be much more than $100, and then you would have a tool with lots of other uses. Plus, you can do the job on your own time. Now, I have seen el cheapo tile saws for sale at Lowe's and such, but I'm not sure how well those would work.
Steven Antonucci
Bought a small one for $80 at the BORG
steven antonucci
Had worked through 4 tile jobs... no brainer...
Small and cheap is all you need. Little slower, but who cares?
S
Jim DeLaney, Austintown, Ohio
About ten years ago, I was doing a bath remodel, and looked into renting a tile saw - $50.00 bucks a day!
Went to Harbor Freight, where they had a cheapo wet saw for something like $59.00. Sheet metal top, plastic water tray, splash lube (no pump), and a 4�" diamond blade.
I figured that if it lasted thru the job, it'd have paid for itself. I still have that saw! It's done two more tile floors for me, and I loaned it out to my Brother-in-Law, and he did at least three tile jobs with it. Little sucker just won't quit.
I've seen the same saw (in different colored cases) at H-D and Lowes.. Prices vary up to about $89.95 now, but HF ususally has them on sale, or there's always a 20% off coupon around.
