Router collet reducer
Jerry Gibbs
I have a 3 1/4 Triton router with a 1/2 collet. My 1/4 bits slip with the reducer in unless I beat on the wrench. If I get a new reducer, are some better? Any other thoughts?
Re: Router collet reducer
Bill Howatt
Make sure you have the slots in both collets lined up so tightening the nut will compress both collets.
Bill
Re: Router collet reducer *LINK*
del schisler
For 1/4" bits, you must use a reducer. The old style reducer required you to line up the slots in the reducer and collet for ease of bit release... that is no longer required. Go to this page and read about this. You may have the old and not the new collett ?? good luck. Make sure the bit is in their right. It can come out and go up real fast.Don't know where it will stop?
http://www.onlinetoolreviews.com/reviews/tritonrou
Keith Newton----Little Rock, Arkansas
Jerry, You may already know, but when you insert a new bit, whether with a reducer or not, you must leave enough space under it to go down, by however many turns of the threads the collet needs to tighten around the shank.
So never tighten with the bit starting at the bottom of the collet, and from now on when given a choice, always buy 1/2" shank cutters. A 1/2" circle has 4 times the area of 1/4" circle.
Hal
Surely Triton makes a 1/4" collet that you can install in place of the 1/2". Those reduces are a real PITA. Had the same thing on a Freud I bought some years back. Called and had them send a 1/4" collet which works just fine. Hal
Re: 1/4 Triton collet?
Jerry Gibbs
As far as I can tell, Triton does not make a 1/4 collet for this router. If anybody knows otherwise, I would appreciate the info.
Dale Lenz
Look at this add *LINK*
Dale Lenz
Last Paragraph
1/4" collet
