PowerMatic Table Saw
Bob S
I have an opportunity to buy a contractors type Powermatic Table saw. It is new, but a discontinued model, and has no motor. This may be the chance for me to update significantly from my ancient 10" Craftsman (vintage late 60's i think) saw. The craftsman saw works fine, but am looking for a bigger unit!
I only got a brief look at the Powermatic saw today, before the store closed, and hardly got a look at it. I will go back in the morning. It has an extended top, to the right side, has the standard (really wide) fence. I have used a Powermatic at a carpentry class before and really liked it.
If i could get the base unit with no motor for $150, how much would a motor cost? I am not sure what size the motor would need to be, so any and all info would be appreciated, as well as are there any issues I should look real close at, other than basic functionality.
Thanks, and I appreciate the feedback.
Bob
Re: PowerMatic Table Saw
I have had one for about 10 years or slightly longer. It's a good saw. I don't remember how big the motor is but it runs on 110 so it can't be over 2hp. Mine has the vega fence which really is great.
It would help if we knew more. I have a Delta Rockwell TS that is forty years old. The original 1 1/2hp motor burned up with in a year or two and I replaced it with a Dayton 2 hp TEFC motor. This is the type of saw where the motor hangs out the back and the weight of the motor is what tensions the belt. Over the years I have also added a link belt and machined pulleys (a fairly minor expense and I also added a Biesemeyer Fence that I caught on sale for $80 when Lowes closed them out. (A major improvement over the crap factory fence.) The saw has been entirely satisfactory in every respect and has done everything I have asked of it. It was good even before the fence was added. My point is, if your saw is the equivalent of mine, it should be and excellent value at $150. A new motor should be available for $200 to 300, but shop around. You might catch one on Craigslist.
OTOH, At $150 I am suspicious that this is a portable job site type saw. They require an internal motor specific to the saw. I don't even know if Powermatic makes such a saw, but if they do, it is a whole separate category and not of the same size and quality as a standard contractors saw.
