What product to seal indoor cedar?
Allen
I am putting a hot tub in my basement and will be covering the walls and ceiling with tongue and groove cedar. My question is what type of product to use on the cedar. I have installed a high flow in-line fan with the vent above the tub to pull moisture out when the tub is in use. I will also be adding a commercial de-humidifier to help 24/7 as needed. Despite have the fan and the de-humidifier I want to make sure I go the best route in terms of prepping the cedar. Using cedar for a deck vs. a closet vs. an indoor hot tub room are all different. Any idea on what to use in my application? I was leaning toward a good quality polyurethane. Thanks for any thoughts.
Al
Re: What product to seal indoor cedar?
Jesper, Denmark
Jesper, Denmark
My opinion is do not seal cedar at all.
It is weather resistant, so really don't need it. As an example, untreated cedar or pine is used in saunas.
You should probably make sure there is a vapor barrier behind the cedar and the wll - between the wainscoting and any insulation.
Allen
Thanks for the reply. The cedar I bought from the big box store says for indoor use. Not sure what make cedar indoor rated vs. outdoor? Maybe the thickness... the cedar is pretty thin (i.e. roughly 3/8"). I did some searching within these archives and it sounds like using polyurethane on cedar might be a mistake. I read several folks that mention shellac. As you mention I could go with no finish as well. It just seems to make sense to seal the wood to limit the moisture absorbtion.
I too thought about the sauna application but I think a sauna is typically on the dry side compared to a hot tub room. Pretty tough to predict what humidity level I will end up with using the fan and de-humidifier. I will be putting down a heavy moisture barrier (6 mil clear plastic) before the cedar as you mentioned.
