Warped board
Warped board
Warped board
Gary Smyth
I thought I saw this answer in the last several weeks but now that I need it I can't find it. If a glued unfinished top begins (colder dryer weather) to warp on what side of the board will a wash coat of shellac tend to promote movement the board back to flat?
Re: Warped board
Re: Warped board
DouginDenver
Never heard this one before. My sense is that since the shellac would be to slow the movement of moisture on that side - in or out - the answer could potentially be either, depending on what was going to happen in the future and what event caused it too warp. In other words, is one side too wet compared to what it "should" be, or is one side too dry compared to what it "should" be? The bowed side of your board has too much moisture, and your cupped side too little. Given you circumstances, which one should change most to allow the wood to go flat? I'll be interested in the respones to this.
Re: Warped board
Re: Warped board
Howard Acheson
No the inside of the curve has dried out more than the outside of the curve. Shellac impeded the transfer of water vapor and what you want to do is to add moisture to the inside of the curve.
Why was one side exposed to the changing environment and not the other? For some reason, the air was prevented to free get to both sides equally.
I would just sticker the board and let it acclimate to the changing environment.
Re: Warped board
Re: Warped board
Jesse Cloud
I think you should wait for seasonal humidity changes to relax the board back to flat and then seal both sides with shellac or another finish.
Re: Warped board
Other considerations
DouginDenver
You didn't say where the board was. If it was laying flat on a workbench or other surface it will often warp temporarily because you have totally different air curculation to the top and bottom. Or if you have a basment shop, the air near the walls is damper than in the room, so it may warp if you lean it near the wall. Assuming the broad was stable before you glued it up, lots of things can cause it to warp for a while if the conditions on both sides are not the same. Certain woods are far worse than others. When my son was in grade school he did a scince project on the subject and I took three lenghs of red oak from the same board, and we threw one out on the lawn so it would absorb all sorts of moisture from the grass side until is was very, very warped. Yet we had trouble keeping it warped. In just a day or two it would be so straight again that I could lay a straight edge across it and it was dead flat.
Re: Warped board
Re: Warped board
Gary Smyth
The top, 30" x 18", belongs to a cabinet with the underside closed off by dust panels and drawers to exposure. it however was flat all autumn. As soon as the weather turned below freezing (it's in a closed but unheated space) is when I noticed the 1/4+" rise on one corner. Today I added 50 pounds of weight to the top, sort of off center to hold the errant end down -- it is not permanently fastened. I'll see if that calms things down a might over the next week. If not, I'll hold off on any coatings, remove it, and put it between battens, then coat both sides once it becomes flat again. It may be Spring before I get to it for finishing.
