On marking dovetails for the hand cut variety
Bill Tindall
I don't cut dovetails on a weekly bases so I don't stay in practice. Hence, I lean on any "crutch" I can find that makes it all go more reliably. One of the problems I have is marking, namely, getting the front(back) to be in the same plane as the sides and another problem is preventing the boards from moving whilst making the marks. No one in the videos , books or demonstrations seems to have these problems but maybe that is because they have more practice.
I found a simple solution for both problems. Additionally, it solves a problem everyone has with the potential for thin drawer sides to bow while under construction. One piece of equipment is required, an angle block.
In this case the angle block is a cheap made- in- India machinist block (Travers Supply) covered with 80 grit abrasive attached with contact cement. Alternatively one could make a block from wood or a section of angle iron.
To mark the dovetail pins, a drawer side and front(or back) is simply aligned and then clamped to the angle block on a flat surface-bench, saw top, etc. Any bow is mashed flat by the clamps, the two pieces are guaranteed to be in one plane and nothing moves whilst marking.
