Glass stain on table
Lynn Reedy
I need to remove a round drinking glass stain from a old coffee table. The table is lacquer finish. Any body got any thoughts or had a likely experience..
Oh yea, Merry Christmas from SODDY DAISY TENNESSEE...
Re: Glass stain on table
Water Ring
in lacquer can usually be removed by applying a bit of lacquer thinner to redissolve the resin. The "stain" is usually just moisture under the finish which will migrate and evaporate with the thinner.
Don't rub, however, as you'll remove lacquer resin into the rag leaving a thin area in the finish.
Besides refinishing the top? You say it is lacquer. Basically you have "entrapped" moisture in your finish. It sort of gets below the surface.
Use Murphy's Oil Soap to remove any polishes. I usually just get a little bit on a clean, soft cloth and rub very gently. After rubbing a bit, go ahead and wipe with a clean, soft cloth.
You then have to pull the water out and repair the finish.
Alcohol usually dissolves the lacquer and the water. It also pulls off some of the finish. You then have to replace the lacquer. You may have left some "repaired" lacquer when you have done this. You still have to replace what you have removed. Try dabbing gently with a clean, soft cloth dampened with a little denatured alcohol. You just want to dab in the area of the ring. Do not rub vigorously or smear it over a large area. Just little circular motions. It may take several tries.
You may want to try a heat gun, hair dryer or warm light bulb first. This can sometimes pull the water out of the lacquer. You still have to "repair" the finish by applying a little more lacquer. Just make sure you do it in the area of the water ring only. If you try the light bulb route, use a small wattage incandescent bulb.
If it is a high gloss finish - good luck. I would probably refinish the entire top.
Get out your steam iron - do NOT use chemicals
Tim Greif - West of Chicago
I've used this trick successfully a number of times and so have friends I've recommended it to. it works quite well with lacquer finishes that have trapped moisture like a glass ring or a bloch from a hot pizza box being set on the table. I would highly recommend NOT using solvent or any other chemical to cure this. You will likely end up with a bigger mess than you have now.
Take a steam iron and set it on hot (no steam). Lay a dish towel over the blemished area. Slowly work the iron around on the water ring with at least one layer of dish towel (start with two) between the iron and the table surface. This will take a few minutes. Just keep the iron moving and check the stain every 30 seconds or so to see if it's disappearing. The heat from the iron drives the moisture out and it's captured in the dish cloth.
I can't take credit for this. It was mentioned years ago by Lee Schierer. It works great. At least it did for me and a few others.
Let us know if this works for you.
Re: Get out your steam iron - do NOT use chemicals
Lee Schierer McKean, PA
:D I was going to suggest the same thing.
explanation and the fix.  It's not trapped water
Bill Tindall
Apparently it is "common knowledge" that the white ring is "trapped moisture". This theory is not correct. While water caused the problem this water is long gone. The phenomena is called "crazing". It is something that happens to polymers and it is not entirely understood. If you were to examine the ring under magnification you would observe that the finish has a bizzilion cracks and these are scattering light like a frosted window.
(Crazing experiment- Bend a polycabonate CD between finger and thumb until it almost breaks. Drop a drop of finger nail polish remover, or rubbing alcohol may work, on the sharp part of the bend. The CD will explode in many pieces as a result of lots of tiny cracks forming in response to the solvent touching the plastic. Wear safety glasses as stuff flies everywhere)
To fix, one needs to redissolve the finish in this area and then let the solvent evaporate. All the places that sell stuff to the furniture repair market have aerosol cans of stuff to accomplish the task. The stuff is a slow evaporating solvent for lacquer. Lacquer retarder would work if you happen to have some, along with a spray gun. Otherwise, buy a can of stuff designed for the problem.
After treating, the treated area may be more shiny than before. If the rest of the finish was rubbed, the redissolved area won't be after the solvent dries.
Re: explanation and the fix.  It's not trapped wat
Okay, if it's not trapped moisture why does the hot iron and towel trick work? The finish doesn't get hot enough to melt, in fact you don't want it that hot.
Second question if the finish is crazed why does it occur under a hot or cold glass of water or a pizza box?
Lee
Paul Vander Woude
I have always used denatured alcohol, which has always worked very well for me. I know it will dissolve a shellac finish, but I have never heard that denatured alcohol would dissolve a laquer finish.
answers
Bill Tindall
The state of the finish: The "white" ring is a result of a multitude of cracks that light bounces off such as to appear white. To fix, the cracks need to go away(fuse back together).
I had not heard of the iron trick but I can speculate what is happening. One does not have to melt a polymer to get it to flow and coalesce. Each polymer has a temperature above which flow and coalescence will happen and this temperature is usually well shy of the melting point. "Cellulose nitrate" lacquer is in fact a mixture of cellulose nitrate and some plasticizer resin, whose purpose is to soften/plasticize the cellulose nitrate. I speculate the heat gets this formulation above a temperature where the minute cracks flow back together, a temperature which won't be very high for the plasticized formulation.
Certain liquids set off crazing, and it is often liquids that aren't solvents. The phenomena is not well understood (as reported by an expert in this field who was asked the question, "why does this happen"?) Water and water vapor, for some reason, cause the finish to craze. Pizza boxes give off prodigious quantities of water vapor, or it could be a result of sausage grease.
The phenomena is inconsistent with "trapped water". The white ring forms rapidly, consistent with something that happened to the surface. Any water or water vapor that diffused into the finish would just as easily diffuse back out through the finish or into the wood. One can't imagine water diffusing into the finish in hours and then being trapped there for months or years. The finish is no barrier to water vapor, nor is the wood. Spraying the ring with lacquer solvent removes the white as rapidly is the finish is dissolved and the white stays gone in the mere seconds it takes for the lacquer solvent to evaporate. Trapped water couldn't get out that fast.
There is another neat example of crazing that you may be able to see. If you can find a Triton water bottle put a finger print on it an then put it in the microwave with some water in it. The steam will heat the oils in the finger print and cause the surface to craze revealing a perfect finger print pattern. My daughter is trying to figure out a murder mystery story where this phenomena will be the key to determining the perpetrator.
Steve Schoene
lacquer begins to breakdown as it ages. It's not all that many years before alcohol is a solvent for the lacquer, while initially it was only a thinner.
FredD
Lee , one only needs to have the experience of spraying Lacquer that has been thinned with a fast flashing thinner or the Lacquer was formulated for Winter use and see the "blushing that occurs as a white ghost in the finish.
This is water vapor trapped under the lacquer and is fixed by using a slower flashing Lacquer thinner and in case of cool air in the shop , to raise the temp.
Sometimes you can get lucky and just hit it with a Lacquer thinner and sometimes it just goes away by it's self.
But in any case the blush is the humidity trapped in the Lacquer and not any "crazing of the finish".
FredD
