We value your privacy.
I humbly seek to tap into he collective wisdom of this knowledgeable fraternity.
When discretionary funds become readily availabe again, I plan on finishing the interior of my gara...er...shop to make it more conducive to spend time there. I'll be insulating /covering the walls and rafters to make it more hospitable. I'll also be covering the floor with plywood ( unless I turn a corner on a road and find a pile of oak or heart pine flooring with a sign "free to good home"). My first question is this:
1.) Do I put the visqueen vapor barrier directly on the concrete, and then glue and nail down sleepers and rigid foam insulation, or do I put the sleepers and foam down first and then cover with the visqueen?
2.) With the lighting, I am considering using 4-tube troffers recessed into the sheet-rock ceiling. In all the pictures of others' shops, I mainly see "wraparound" flourescent fixtures that are attached to the ceiling. Is there any advantage to these, other than ease of installation? It seems they might throw a bit more light, due to the fact the fixtures throw light sideways as well, but I like the way troffers (suspended-ceiling style lights) are recessed into the ceiling and are more difficult to hit with any stock or sheetgoods I might be moving around.
As always, thanx in advance for any and all suggestions.
More important than the question you asked, which i don't know the answer to but your local full service lighting store will, is to make the walls and floor light in color to reflect this valuable light back to the working area rather the wastefully absorbing it.
If you want to glue and nail your sleepers, you'll need to put the vapor barrier on top - otherwise, you're gluing them to the vapor barrier, not the slab.
If you use treated sleepers - as you should - I would think you'd want the vapor barrier on top of them. I know the newer pressure treatment is supposed to be safe and all, but I'd want as much between me and the chemicals as I could get.
When I built my shop, I laid the poly on the slab, under 5/4" x 6" PTSYP (1" actual) sleepers 24"OC with 1" rigid foam between them, overlaid with 3/4" T&G 4'x8' Advantech decking. I also left races under the decking to run 120 & 240 wiring for floor mounted outlets.
The shop has a clear 10' height to the base of wood/OSB I-beam joists. I ran wiring for ceiling mounted 120v outlets on two circuits that split the load for 19 el cheapo two tube T8 hanging fixtures.
You might want to check out the latest Tools & Shops issue of FWW to see a garage made into a shop. It is quite informative and discusses the fastening of 2x4 sleepers to the concrete floor, followed by a plastic vapor barrier, then T&G plywood. His treatment of insulating concrete walls is interesting too. I don't recall what the author did for lighting and I don't have that issue handy or I would check. If you have access to a broadband connection, here is a link to a FWW video regarding the article.
Just a thought from the GI trouble shooter : now-a-days the readily available (without spending commercial prices) light fixtures come with plugs. Instead of installing fixtures, install outlets. In the missile trade we call this chump-changing. When a fixture goes bad (and they ain't worth fixing) just get a new $20 fixture and plug & play. Also, this gives you another outlet to "drop" an auxillury light down for close work (No such thing as to many outlets !).
check whether you need/should have GFCI outlets. Our inspector here requires them in shop spaces, regardless of whether it was intended for lights. Makes sense, since you can never tell what people will plug into an outlet.
You might consider lumber Liquidators ,or other hardwood flooring suppliers.LL has a utility grade 3/4" oak floor that is $0.99/sqft.not quite as cheap as plywood but a different look.Also alot of labor,but I figured I'd throw it out there for you
I have a suspended ceiling. Therefore I have 2 x 4' troffers. There is nothing wrong with them. But in your application - why bother cutting holes in perfectly good sheet rock? That's a lot of work. If you want to do it, fine. I would make a framed opening and have rabbets around the edge and drop the lights in like you would in a suspended ceiling. Just remember that you have to open the lights to change bulbs and clean the diffusers.
I would recommend getting some good directional task lighting. I have track lighting. I've got a friend who put recessed can lights over his bench. Whichever way you go, make sure you have a little more light where you need it.
It sounds as though the best route to go is to put the vapor barrier on top of the sleepers, and as far as lights are concerned, I think I'll go with the wrap-around style, due to lower cost and NOT having to do the work of fitting them into the ceiling. An electrician neighbor has offered to observe me doing the wiring, and will sign off on the installation when the inspector comes around. I appreciate the idea of running wiring under the flooring, as I HATE tripping over cords.
I appreciate all the responses. It just goes to show how great this forum is!
