Issues with CrystaLac grain filler?
DouginDenver
In an age when even a toaster comes with 30 pages of instructions, CrystaLac sets a new standard for minimal and poor instructions. All the instructions say are dries fast, wipe on and "trowel" off, and sand between coats. Not a word about how long to wait between coats, how long to wait before topcoating, and, most impotantly, any topcoat compatibility issues. It is a "waterborne" product, and looks and acts like slightly thicker water based Varathane - kinda like thick milk but dries clear. Before I contact the comapny, I'd thought I'd ask if anybody here knows of any topcoats that will not adhere to it well or has any other advice.
Re: Issues with CrystaLac grain filler?
Steve Schoene
Haven't used it, but have heard a number of comments about it suggesting it shrinks quite a bit. I guess that means to use it you should clean off the first coat and then give it a rest to get the shrinkage of the first coat completed before you apply the second.
Personally, I much prefer oil based pore filler--plenty of working time so you seldom have any serious sanding to do just scrape and wipe off the excess.
Hi Doug,
I've used it for years to do filled pore finishes on walnut; haven't had any problems. My routine goes like this:
1. Sand the surface to 180 and vacuum off well.
2. Apply a spit coat 3/4 lb cut of dewaxed shellac; let dry for 2 hours.
3. Apply a first coat of Crystalac filler and work into the pore with a plastic straight-edge going first with, then at an angle to, the grain. The "squeegee" will remove the excess. Allow to dry 2 hours.
4. Resand with 220 paper.
5. Apply a second coat of filler, going lightly with the squeegee to leave more filler on the surface. Allow to dry well (2-3 hours).
6. Resand with your final grit paper on a flat wood block moving with the grain. I find that a power sander's platen surface tends to flex too much for a truly flat surface. The dried filler sands easily, so this isn't the chore that it might sound like. Shaped edges and molding profiles can, of course, be a pain.
7. Apply your finish. I've used shellac, NC lacquer, oil poly, and good waterbornes over Crystalac with no issues. Remember, however, that any waterborne finish applied to a raw-sanded surface will tend to raise the exposed wood fibers. Perhaps this is what people read as the filler shrinking. Another spit-coat of shellac before application of a waterborne finish usually solves this problem for me.
Which oil based filler?
DouginDenver
Which one do you prefer? I'm just starting to play with fillers. You are correct about Crystalac shrinking.
Re: Which oil based filler?
Steve Schoene
I think the best I've uses is Sherwin Williams. It's filler is silex which becomes more translucent than most, and shrinks very little. Problem--only in gallons and only from the industrial type stores not the retail stores. Old Masters seems OK, and has a high proportion of silex. The Behlen shrinks a bit more but has been widely used. It comes very thick--so it goes far if you thin to the consistency of heavy cream using naptha.
A couple other questions
DouginDenver
I wondered about the Behlens' claimthat I need their special thinner to thin it. So Naptha is fine?
What are the range of things I can use to tint Behlens? Can I use liquid Transtint dye from the bottle?
Re: Which oil based filler? *LINK*
FredD
Any S-W store carries this or can get it.
http://picasaweb.google.com/FredD17209/SWFiller?authkey=Gv1sRgCK_gqKuW_5WWtQE&feat=directlink
Tint
Transtint will not do well with oil-based products. Jeff does have an adment to use Transtint with oil finishes, but I think he specifies that it's only for use with clear finish coats rather than stains. He would , however, be the best one to ask.
Re: A couple other questions
Steve Schoene
One good source of pigment that is easy to find is artist's oil paint. The earth colors--raw and burnt umber, raw and burnt sienna, yellow ochre plus van dyke. Powdered pigment works (I ended up with about a lifetime supply when I visited Olde Mill cabinet shop some time ago) but more effort mixing is required. Universal Tinting Colors UTCs also work.
