router template bushings
Jerry Gibbs
how do I make an acrylic base for an old router that will accept bushings?
Re: router template bushings
Re: router template bushings *LINK*
You might contact Pat Warner and ask if he'd make one (or has one in stock); see linky.
If you make your own and wanted to use the Porter-Cable type bushings that go into a rabbeted hole in the base, I suppose you could use a pattern bit to get the diameter of the basic hole right, and then use one of those stepped rabbeting bits - or a big nylon bushing on the bearing of a regular rabbeting bit - to do the rabbet.
If you do make your own, look for scratch-resistant acrylic. It's a little pricier, but should stay clear longer. It's scratch-resistant on one side only - make sure you put that side down in the final layout.
http://www.patwarner.com/
Bob Entwisle in NJ
I picked up one of these (see link) on sale at woodcraft a while back for 20 bucks. I stuck a template bushing in it, and using the centering bit, marked and drilled it for the router that I wanted to fit it to, which was not one of those on the list. I think they aslo sell an undrilled base, and you could pick up the centering bit separately, which might be a better option. (I was just being cheap and bought the predrilled 'on sale' base). It all worked out in the end and I'm happy with it. You need to mark the mounting holes carefully and then should counter bore them on the DP (I used a small forstner bit for the counter bore) and then drill the through hole.
Bob in NJ
http://www.woodcraft.com/Product/2004856/7680/Router-Base-Plate-with-Centering-Pin.aspx
