bow front drawers-2 down 7 to go
Bill Tindall
The center drawer is dovetailed and fitted as is the right drawer which is hanging. Still to go is veneering the front and adding cock bead.
The bow front has added a multitude of complexity to drawer making, especially given that this if my first. Note I have left the drawer front back flat to aid dovetail marking, veneering and just plain holding. It will get its curve sawed just before gluing it together. The half blind pins have been slow to chop. Waste removal is slower than for a flat front drawer where "aids" can be employed. It's all hand work.
I have one problem to solve, cutting the drawer bottom groove. Is there a router bit akin to a rabbit bit that will cut variable depth gooves- in this case 1/4" by1/4" deep?
I know you can get slotting bits that will make your groove in several passes and perhaps if they make it, in one pass. You groove might be deeper than 1/4" though with the slotting bits, so make sure you groove it before cutting the bottom. I know Stanley also made a tool to cut a curved rabbet with a special plane, I think for only about $600, perhaps Lee Vally will make one that does rabbets and grooves
