SnowBlower Wax??
SnowBlower Wax??
SnowBlower Wax??
Thomas Norton
We got hit with a good storm last night and this AM I was having a problem with the snow "sticking" to the augers.
I have the blower in my shop warming up and melting off right now so I thought I would ask.
What would be a Real Good choice for wax for this situation?
Thanks!!
Re: SnowBlower Wax??
Joseph Mulherin, Sr
We used to use a bar of paraffin to swipe the blades occasionally, also maybe some beeswax would help.
David Dircksen
I spray the snowblower and shovel with WD 40.
Same here Silicon spray the heck out of it
Dustmaker Mike
I also do the chute and out side of the the snowblower at least once during the season.
Re: Same here Silicon spray the heck out of it
Thomas Norton
Well, since we cannot get out because of the snow all I had in the shop was Butcher's Wax. It worked for about 5 minutes! Then I hit it with Wd-40 and it help for a while. Will push through for today but next chance will pick up a can of silicone spray.
Thanks!!
Jon Weisenbach
Thomas....
I had a very large jug of "Protect All" left over from our full-timing RV days and I tried spraying it on my 5' ATV snow blade a few years ago and have used it since! Snow slides right off of it and I now even spray the wheels and tires so they stay clean too! Worth a try in my estimation. (ps) use it alot here in Montana! :D :D
Keep the machine below freezing
Grant in Iowa
One thing you can do to prevent snow from sticking is to keep the machine below freezing. This will prevent the snow from melting and then refreezing when you begin blowing snow with it.
Same is true for a snow shovel.
The silicone spray also helps.
FWIW,
Grant in Iowa<--snowing here right now.
Not Snowing here in Alpharetta
Dustmaker Mike
but the LOML is getting a lot up in Ohio. Boy I am glad I bought her a Snowblower(-; With an electric start even.
Need to call Clark Griswold!
Tony - Memphis
Not sure if you saw th emovie, but the non stick coating "his company was working on" worked mighty well on his saucer sled!
Tony
Galen Vetterick
It might have just been the operator but I never found WD40 or silicone did anything to prevent wet and slushy snow from freezing on the cold steel slow auger.
I often wondered if a closed center drum auger would do better at moving the heavy stuff. In the open auger it just seems to fall back into the center and roll.
I had a single stage two cycle snow blower that was just a high speed auger. It was actually better at moving heavy wet snow than my bigger two stage.
I just used red Rustoleum paint at the years end to keep the scratches and bare metal from rusting till the next winter and it wore it off again.
Townhome city living with no snow worries is one of a few advantages of not living rural on a long private road and snow to the top of the garage door anymore. I still miss a lot of the good life there!
Marty in St. John's
Galen, I had a similar problem with my 14 year old Honda snowblower and I talked to the service technician at Honda. He informed me that there were probably cracks in my belts causing the slower speed of the augers to throw the snow. Sure enough there were a lot of cracks in the belts so I replaced all the belts and bearings. I also took a grinder with a soft abrasive wheel to remove all the paint, pitting, and rust from the augers and impeller. I applied a good spray primer and good black spray paint to the augers and impeller. The machine works perfectly now.
DavesNotHere
