Finishing matching
Gary Smyth
Finishing
I bought some Transtint dyes to make effort to match some remaining finish on an older cabinet that also has some unfinished new wood. In my mind this is a overall color base coat to be followed by other color finishes depending on the �look� after it is applied. I�ve been idle doing, by thinking about this, for the past week reading about the possibilities. I remain not knowing the proper sequence to follow. Do I apply the dye first and match as closely as possible followed by a washcoat of 1 pound blonde shellac? Do I do the washcoat first and then the dye (the dye in denatured alcohol will blend with the washcoat)? Do I mix the two together to begin with and if the colors match well enough (after test pieces) then what do I use to seal it? I�m thinking that a true match is not possible with just the dye (it will be used to get all the wood about the same shade) and a gel coat will probably need to be used to unite the colors later.
I�ve researched Dresdner, Jewitt, Bridgewater, Flexner, Crump and the more I read the worse it gets.
Also is there a temperature minimum before doing this?
