enclosed motors
enclosed motors
enclosed motors
Jerry Gibbs
Is the reason for enclosed electrical motors in a woodshop safety, motor life or both. I am planning to build a drum sander and need a motor. I have a non-TEFC available. If the issue is safety, should I change the other open case motors in my shop which often has airborne dust?
Re: enclosed motors
Re: enclosed motors
Tom MacGregor
I've seen a couple of motors overheat and smoke the sawdust inside over the past 40 years, but I've never heard of one actually starting a fire. Woodworking machines have been sold with open motors for a long time (cheaper for the manufacturer) and have been safe enough not to spawn lawsuits and legislation. All motors work better if they're clean and lubricated. If it has permanent sealed bearings you run it until they start to fail; if it has grease fittings you give it a shot of grease once or twice a year depending on how much you use it. If it's an open motor blow it out with compressed air on a regular basis. If you have a motor already go ahead and use it.
Re: enclosed motors
Re: enclosed motors
Dan Donaldson
The main issue that I have seen is that the sawdust gets into the start contacts and the motor will not start.
Re: enclosed motors
Re: enclosed motors
Howard Norman
I would use the available motor if I had your situation. I would also realize that I should use compressed air to blow the motor out once in awhile to prevent the sawdust from getting into the starting switch.
Re: enclosed motors
Re: enclosed motors *LINK*
Roy Anderson
TEFC is the gold standard, but many woodworking specified motors are TE but not FC. You can also get woodworking rated motors that are ODP (open frame, drip proof) which have their ventillation holes located toward the bottom of the motor, also having sealed electronic starter switches, double insulation and double sealed bearings to prevent sawdust from entering the bearings.
See link for more info.
So from that, I take it that the idea is to keep dust out of the starter switch and the bearings. If your motor has an open switch box and open bearings, I wouldn't use it.
http://www.electricmotorwarehouse.com/woodwork_motors.htm
Re: enclosed motors
Re: enclosed motors
AZ in Colorado Springs
My tablesaw has a TEFC motor. A few weeks ago it would not start. took the motor to a tool repair shop and they had to clean sawdust out of the internal switch which energizes the main winding.
So, "totally enclosed" apparently does not mean dust-proof.
Re: enclosed motors
Use what's readily available....
John in NM
TE vs open is not such a big deal. I kinda prefer the open motors as a blast of compressed air every now and then seems to take care of most problems. Many open motors run for years without even that much care. Sealed bearings in an open motor will last years in any case. If you really want to use a TEFC motor, happen to have one, or get one cheap, then by all means use it. But I don't think I'd call it an absolute requirement for a quality machine. I'd rather have a nice open GE motor than a Chinese TEFC any day, because the components would likely be better quality and longer lasting (I would however expect a premium TEFC to last a bit longer than a premium open motor).
