kitchen rock job done
Bill Tindall
It took a lot of shimming to get the base units all in one plane. Rock doesn't flex to accommodate irregularities. My woodworking yesterday consisted of cutting lots of shim stock. The installers were exceptional. With diamond tooling they cut and shaped the rock as easily as I do wood. The arc on the counter end was done free-hand with an angle grinder and diamond blade, ditto the sink cut out. They had a diamond studded rubber pad that fit an angle grinder and it mowed off rock as fast as 60 grit on hardwood.
The tops are fasted by 1000 pounds of gravitational forces and a bit of caulk.
Now its back to cutting and assembling bow front drawers. Much more challenging than orthogonal drawers for sure, especially the sections with divided drawers that are segments of the full bow front arc.
Re: kitchen rock job done
Dan Donaldson
Very Nice. Need to see pics of the drawers when done.
Galen Vetterick
Very nice! I favor the lighter stone countertops.
Before you get back to woodworking put a little food out for that poor bird as I see the ground looks white and no food in the feeder. :>)
Very nice
It is amazing to see the specialist installers - part of it's tooling, much of it's practice.
And, yes - there's nothing like having to get the tops of the cabinets dead level to inform you how far out of level your kitchen floor is (in our old house, 3/4" in ten feet - oddly, you can't tell when you're walking around in the room).
FredD
I bet that makes your Wife smile.
FredD
bird's fed
Bill Tindall
couldn't get out the window till the sink caulk cured.
