We value your privacy.
Or do ya'll have another cheaper way of stopping router bit tear out?
I'm taking small cuts by raising the router bit millimeter by millimeter. I'm still getting a little tear out on the end grain. Router bit is not really old - and it cuts well on the side grain.
I remember being exhorted to buy the European/anti-kick back style bit, and its worked very well for me. Freud's design may result in a better cut. Admittedly I replace older bits, so enjoy the quality of cut I am used to. However, tear out and/or roughness on end grain is a discernable condition, so I do incremental routing as you do. Whether or not the new Freud quad cutters are actually better and worth the added expence, I can't answer. It stands to reason that an extra cutter or two would make a lot of difference. However, I am not about to spend a lot of money to find out. Patience and sand paper I still have plenty of.
If thats what I think it is, its a cutter around 4 inches in diameter and there could be a speed problem that is literally shattering wood fibers. A large cutter has a very high edge speed at the usual router RPM's of around 20-25,000 RPM. I seem to recall that a panel raising cutter has an edge speed of over 200 MILES per hour. Large cutters have to be slowed way down to the range of -say- 10-12,000 RPM to get clean cuts.
For a shaper with a comparable sized cutter the recommended RPM is 8,000 to 10,000.
Try the slowest RPM you have and it may give you the results you want.
do the end grain first than run the board long , and across grain again . this clean's tare out on your end grain Remember end grain long grain end grain and end grain last. Now if you still get some tare out remember to leve we will say 1/8" now run that on the table saw. The only way not get end grain tare out is to back cut which i don't like to do. Not the safe way to do. Or run a cull board held against the back of the end grain. Still may get some. Do the table saw thing. I have made probly 500 or so jewelry and trinket box's and i use the router on both top and bottom. That is what i do . But i use amana bit's which is good quality whiteside are up on top also . The box store's i don't use them not the best quality
For end grain the bit needs to be especially sharp, and some angle to the bit so as to get a shear cut is desirable. I am going to bet a new quality bit will solve the problem.
Your talking about the number of flutes a bit has and the rule is the more flutes , the smoother the cut and the slower the feed.
A carbide bit made by a quality tool grinder like Bosch for instance only needs three flutes or even two to get a smooth cut.
In your particular case a down spiral cutter will give you a cut with absolutely no fuzz on the top side of the cut.
If the bit your using is sharp, you only need to make a pass that will be close to the finish cut and then make one more that cleans up the first one.
I think based on a lot of observation of others doing many incremental small cuts ,that approach only increases the likelihood of a slip that ruins the profile of the cut and burnishes the wood which you need to avoid.
