OT Internet Conncetion Speed
Tom Rex
I'm have a Verizon FiOS internet connection an want to know how I can find the speed that I connected at.
Tom Rex
Here's an online test I've used *LINK*
Bruce, a MN Galoot
CNET Bandwidth meter
paul in AZ
network.msu.edu/public/speedtest.html
Using Bruce's link I got 25,000 kbps and with the Michigan State link I get 2.34 MBPS. Pretty near identical link speeds.
Trying again. Posting the full website address gets the message shunted off to the moderator. Maybe this will work.
You need a profile to post links
Check the FAQs to see all the reasons you should have a profile. It takes two minutes and the payoff is worth it -- text formatting, uploads from your computer, ability to paste links into the message, multiple photos in posts, emoticons....
Thanks,
paul in AZ
http://network.msu.edu/public/speedtest.html
Re: You need a profile to post links
paul in AZ
Thanks ellis. One of those "if everything else fails, search for the directions"
Here's what I use ... *LINK*
Mike Farinella
Most of the network pros in my area use this one.
http://www.speedtest.net/
Woo Hoo Spartans
Dave Bair, Eaton Rapids, MI
Me, too
When you go there, don't hit the "begin scan now" button or else it will try to sell you a registry cleaner. Wait for the "begin test" button. Speedtest.net tests your upload speed in addition to your download speed and it checks your ping time in microseconds.
Re: Me, too
Dan Donaldson
I don't want to even try it right now. If I were to try for a mail speed test, I would have to put a stamp on it ;-(
I sure was spoiled. Oh, well, there are a lot of other advantages here, one of which is a general lack of that white stuff and below zero temps ;-)
(Just waiting for more trunk capacity or 4g in this area)
So how to "clean up" registry errors?
Henry (Raleigh, NC)
So our old PC does run slower and slower. I have cleaned up cookies and saved files from internet usage, but I am not all that familiar with registry errors. Is there a good clean sca/repair tool? Free would be great, but i am willing to pay for one.
FYI - This is a Windows XP home edition.
Henry
Be careful with the registry
... and with software that is supposed to fix it. I've seen a lot of those programs that are just a scam to get you to buy something unnecessary.
I don't know what you mean by your computer running slowly. Are you talking about browsing the Internet or running a program locally? When you click on the Task Manager, which processes are eating up your CPU power? And how old is that machine, anyhow? How many things are running at the same time?
If you don't know about these things, I'd take it to a geek who can diagnose what is wrong. It is very difficult for us (me, at least) to know what to tell you.
Re: So how to "clean up" registry errors?
FredD
Being nearly clueless with computers Henry, for what you describe , I have run for sometime a utility called COMODO .
Works good and does several things besides fixing corrupted Registry's and the best part is that is free and does not run a scam on you like Ellis was mentioning.
FredD
The best and safest way
Dan Donaldson
You won't want to hear it, but if you are running on an old (3+years) installation of Windows, the best way to fix it is to backup your data, format the drive and completely reinstall Windows, your programs and then your data. Over time, things get corrupted and modified to the point that unless you really know what you are doing, it is nearly impossible to really fix it without just starting over.
One other thing that you might want to try if you have not done it lately is to get rid of any ~temp files and defrag your drive. That can sometimes make quite a difference in speed.
