REAL MILK PAINT
Bond life for cyanoacrylate (CA) adhesives
Bill Tindall
There isn't a definitive answer for how long a cyanoacrylate (CA) bond will last in wood. The best one can do is look into what CAN happen to this stuff and worry if something bad can happed.
Background: There isn't much material in a glue joint and anything that affects the one molecule thick layer of glue on the substrate surface will be especially important. So any degradation initiated by the substrate, in this case wood, is very bad news. For example a CA bond on glass can fall apart in days because of rapid degradation at the glass surface. Any degradation that affects the toughness of the cured glue that is between the pieces joined is also bad news. Light is bad news for all glue but wood joints are fortunately dark so photodegradation is unlikely to be a factor in joint life.
The common glues used-white, yellow, epoxy- aren't susceptible to any chemical reactions that are likely to affect their toughness under normal operating conditions (i.e., their molecular weight is unlikely to be affected by age). This is not the case with CA glue.
CA glue reacts fairly rapidly (days) with water and this reaction destroys the material toughness and hence the bond strength. I could not find reports that investigated whether water vapor( humidity) or water absorbed in wood will react fast enough to be a factor on a "many years" time scale. I would expect water vapor(humidity) and/or water absorbed in the wood will very slowly react to degrade the CA.
Furthermore, CA is a hard, brittle glue with less "give" than conventional wood glues. Glued up structures with cross grain elements and different woods and grain orientation will be subject to stress that will tax the joint, especially if the glue does not have adequate toughness, either because it is not particularly tough to begin with, like CA, or it has degraded, which CA can do.
The bottom line: CA glue has chemical and physical properties that are worrisome as a candidate for long term (years) bond strength. Perhaps in your particular application and use conditions it will last as long as you need it to last.
Personally, I would use a traditional wood glue for any application where I wanted the bond to last a long time. I use the fast set properties of this glue for holding parts in place for screwing, etc. It works great for holding hinges in place while scribing and/or drilling pilot holes. But in these cases another fastener provides the permanent bonding.
Re: Bond life for cyanoacrylate (CA) adhesives
This came up in a recent thread over on Hand Tools *LINK*
Linked below, where the subthread on CA glue started.
http://www.woodcentral.com/cgi-bin/handtools.pl/pro/search/pmd/sread/srchid/21514VEIuMTgZRucvVEm1291397768/spage/1/sanc/151250/sbid/3000/md/read/id/151241/sbj/using-the-right-adhesive/
I have never trusted CA for any construction with wood. Don't like working with it anyway.
Tom
Dale Lenz
Makes a good small defect filler
Dale Lenz
