Will phenolic ruin a bandsaw blade?
Henry Higginbotham
I need to cut an 11" diameter circle from a piece of phenolic about 1" thick. In fact, I'll have to go around it twice, as it needs a 45� bevel on the underside after it's been cut to nominal size.
The obvious tool, if this were wood, is the band saw. Is this likely to ruin a steel blade? The only carbide-tipped blade I have is a 1" Lenox TriMaster and (a) I'm not willing to risk a blade that expensive and (b) it wouldn't cut that tight a radius, anyway.
I suppose I could also rig up a jigsaw to do this, but it seems like the band saw would make a better cut, if only the blade would survive. (I've cut phenolic several times with a metal-cutting blade in the jigsaw, and with carbide-tipped table saw blades and router bits.)
Re: Will phenolic ruin a bandsaw blade?
Is it filled or reinforced?
Bill Tindall
If it is glass fiber or glass cloth filled, or otherwise mineral filled, which is likely, it may dull the blade. But so what? Use and old blade and consider it expendable. Unless your saw is huge, like 36", the blades should be costing $8-12 and if you use one already worn the job isn't very expensive.
Phil Joines
I've cut a fair amount of canvas (brown/tan) phenolic with both band and table saws without any abnormal effects except the smell.
Galen Vetterick
Agree on the smell. I too cut linen and cavas phenolics in 1/4" sheet and up to 2" diameter thick wall tubes. Band saw blade needs more teeth per inch cause it is considered hard plastic but too many teeth and it will glaze on cutting.
I'd think a dull bade would track very poorly in 1" material so would use a good blade. Never seemed to be a problem on excessive blade wear/damage.
Any rough cut on rounds were machined on a lathe anyway in my case.
Re: Is it filled or reinforced?
Henry Higginbotham
Not sure. It's not like some I've seen where the canvas was visible. This stuff is black, and smooth throughout. When cut, it appears slightly brownish until it has been sanded and polished.
I've never found any $8 bandsaw blades, even for my 14" Powermatic. I was planning on doing this on the 16" MM (154"), and blades seem to be more in the $15-19 range.
It's a freebie job for a friend, so I was hoping to keep the costs down.
FredD
Cut a shallow 1/4" groove in the Phenolic with a router and flip it over and run a flush cutter using the first cut for the guide.
Then chuck a 45 degree bit for the bevel.
Assuming you have the appropiate bits of course ;-))
FredD
That sounds like it would work, except
Henry Higginbotham
Would have sworn I owned a fairly large 45� chamfer bit, but it's not showing itself today. >(
Thanks to you and the others for the suggestions. I have a couple of weeks before I have to make the part, so I'll buy either a cheap bandsaw blade or a chamfer bit. What better way to find the old one than to buy a new one?
Finding old tools and parts
"What better way to find the old one than to buy a new one?"
There are two possible explanations for this:
1) The old one hears the new one singing as you enter the shop, and comes out to play, or
2) The old one gets territorial/jealous when the new one arrives and comes out to assert its dominance.
Scientists are still trying to figure out which explanation is correct.
Walt Smith
How about a shop made router trammel or circle cutting jig like the jasper jig and carbide bit?
