We value your privacy.
Now that I just installed in a new trash compactor and a new dishwasher, the old oven looks out of place. My wife asked me to investigate a new oven (she's actually been on the fence for the last two years).
Simple question: Is installing a 27" double wall oven a DIY job?
I'm not concerned about the electrical connection. What I'm more concerned about is how heavy the oven is, and whether two average persons can lift the oven into its resting place.
If I can install the oven myself, the money saved can be applied toward a better (or to be exact, costlier) oven.
My present double oven was installed by two men. I was not one of them, it was installed by the cabinet installers. I may have helped some, I don't recall for sure since it was almost six years ago. If you are talking about doing it with the aid of your wife I would have my doubts of that combination.
When we redid our kitchen, our contractor son was able to work with us for much of it; but he had to go work on another job when it was time to put in the kitchen cabinets. I installed the upper cabinets with the help of a material lift, a kind of hand-cranked forklift I got from the local rental yard. You would not need to go as high as I did, and might be able to get a smaller one than I used (which cleared our back door by one inch, or maybe it was 1/2").
Or, you might be able to get some cheap sawhorse brackets and make up a stand the height of the opening to put the oven on, so you could then slide it in.
Not having ever put in a wall oven, I don't know if either of these approaches would work. But you might be able to come up with a way to take the weight of the oven while installing it.
Considering where you live Hoa, it probably would be a good idea to not advertise your appliance upgrading , unless of course you got a Electrical permit and had it signed off.
Depending on the Jurisdiction , most places in CA , had started to refuse permits of the tech trades, (Plumbing, Electrical, and HVAC) to home owners who wanted to do it their selves at least 15 years ago.
Since you will undoubtedly ignore this friendly caution, at least make sure the wire and breaker match the requirements for your Oven.
Ovens are relatively light weight. As was suggested, use a temp stand to facilitate sliding into the space and hold it while connecting the wires. not very difficult. It will come with installation instructions. Go for it.
maybe it's because I live in a small town, but I've done a kitchen remodel and two bath remodels on permits, with the "homeowner will do it himself" box checked off on the permit application, and never had one bit of fuss from the inspector.
I don't know what Alameda's like, though.
I did cheat, though, and had the appliance store from whom we bought the fridge, oven, and dishwasher install them. They had some excellent tips and techniques that I wouldn't have necessarily known about - unrelated to safe installation, more related to convenience and (in the case of the dishwasher) the ability to spot leaks when it starts to leak down the line.
I "lift" heavy objects by tipping them to one side and having my assistant put a 4" x 8" x 16" concrete block under the elevated side. Then I tip the other side up and put a block under that. This is repeated until I have reached the desired height. The blocks are cheap, very stable and reusable. I elevated a 125 BTU boiler 20 inches this way and never broke a sweat.
As stated, my only concern is the weigh of the oven. I read some of the installation instructions found on line, all of them say that the doors of the oven should be removed before lifting the oven in place. That will make the task easy enough for my son and me (my wife only supervises ) to lift the oven in place (with some temporary support if needed). I think the oven is probably as heavy as the 50 gal. water heater that I replaced last year.
In terms of permit, the city (not Alameda, BTW) requires it only when I add or re-locate a built-in appliance. Replacement doesn't count.
I did one in my last house and it was not any real problem. My wife helped me put it in and as I recall, it wasn't that heavy. Make sure that you build in the required clearances to flammable objects and wiring requirements.
My son and I are working on a house for him. He goes on line and looks up all kinds of specs. I bet you can look up the weigh in a matter of minutes.
Take the doors off and of course remove the shelves. That will require you remove the turkey and the ham. Be sure to let it cool down before you start.
Most of the double oven specs we put in say the cabinet floor for the oven has to support 300 pounds. This is not light weight in my opinion. I don't know if the oven actually weighs that much, that is just what the specs call for. Two pretty strong people can install a double oven but I wouldn't want two lightweights on it. I'm sure the weight varies by brand; most of the ovens we put in are high end brands.
My brother-in-Law and I installed one in his house a couple months ago. It was pretty heavy - around 170# - but once set on the bottom rails, it slid right into the cabinet I'd built. We stacked it on top of a warming drawer, so the whole stack was about 5� feet high. That put the control panel for the ovens right at eye level for my (fairly tall) sister.
As with you, weight was my only concern. I did a very serious structural reinforcement of the cabinet and then with Milk crates and plywood odds and ends, I built a surface, at the correct height, to support the new double oven. Wlth the unit supported, I did the electrical connection and then just pushed it into place. The time and effort to carefully make the support was well worth it and was why I was able to easily do the job.
I installed mine, unaided. I built a temporary platform slightly higher than the bottom rail to support the unit while I wired it up. It slid right in with a little compression of the oven sides to clear the stiles. Do be certain of your measurements.
That is well and good Bill , you actually had it permitted and signed off, which seems to be the opposite trend with a lot of handy home owners,
This little story is one I had to keep a straight face on when the lady contacted me for a Kitchen job and they had in advance , bought a Jenn Aire range and while we were going over the plans she mentioned that her new range which her Husband who was a Sheet Metal worker , at Alameda Naval Air had already hooked up and said the burners didn't get very hot and the oven didn't work.
I pulled the unit back from the wall and looked and said I would send over a Electrician to rewire it and do not use it until he says so.
Her Husband being the Macho know it all we all know , had hooked it up with rip cord. That's the trade name for lamp wire which is 16-18 AWG.
Those Jenn-Aires required a 50 amp circuit and a #6 AWG connection.
Previous residents/owners had done some things that, when I found them, had me trembling and made me extremely grateful we hadn't all died in our sleep when the house burned down due to electrical hookups.
