ADVERTISE HERE - FREE TRIAL
Which Planer to Buy?
David Miller from Iowa
About 10 years ago I bought a 12" Jet planer for, I think $230, and I have abused that thing with dirty found lumber and anything that would fit through there since that time. But it finally gave up the other day - not complaining, in dollars per board foot I did very well and we made a lot of swell projects together. So I'm looking at the Ryobi cheapie, the Ridgid and the cheaper Dewalt. I'm not spending over $400 so save your keystrokes on the efficacy of buying up.
Do you have recommendations or testimonials for this class of planer? Thanks, David
Re: Which Planer to Buy?
Ron in Sterling, CT
I picked up a good, used, cheaper model Dewalt (735) a couple years ago, and have been very happy with it. It was a big step up from my 10" Ryobi.
When I was looking, Ridgid was getting good reviews in the mags, but I don't have any direct experience with one.
Ron
FredD
Ten years is a good life for this Planer type , buy another just like it.
They are all the same.
FredD
del schisler
i have the 13" ridgid planer and i use it every day. I haven't had any problum's with it. It come with a extra set of doubble knive's . They last quite a while. You can use a woden block of wood and 600 grit paper and totch up the edges and still go with them. Works for me. With a good vac system which i have the delta it works good. If i needed another one i would buy the same. Not brakeing the bank. Good for the $$$'s . Also i have the jointer 6" and it is used every and work's fine out of the box. Just set up the fence and you are good to go. No end dent like most have. I like the bed's that move infeed and outfeed if you need to adjust the outfeed. But i have never toutched mine. Good out of the box. My 2cents
Dave Bair, Eaton Rapids, MI
I've had the 2-speed Delta bench-top planer for 8 years. Aside from an occasional deglazing of the feed rollers and ridiculously easy double-sided knife changes, I've had zero issues with it.
AZ in Colorado Springs
I have the Rigid. Bought a factory reconditioned model at an outlet mall. I love it. Came with infeed and outfeed tables about a foot long each. Very little to zero snipe, even planing 1x5 maple boards about 79" long.
Joe Mohnike
I'm looking too. I have been looking at the DeWalt which has 3 blades rather than 2, a few more bucks and it is heavier, so not as portable, but I think the 3 blades will give a better cut. In the mean time I am still useing my 10" Ryobi which purchased 30 or 31 years ago and still does the job.
Joe
Jon Weisenbach
David....
Don't know if you have the need but I just got the Jet 10" combo planer/joiner and it's a terrific machine for about the price your talking about. Several of the dealers like Amazon and Tool orbit and others have them on sale right now. May be worth a peek!
Louie Lovas
Louie Lovas
I am no fan of benchtop planers (sorry to buck the trend of this thread). The primary reason is that the infeed/outfeed rollers are rubber. I typically work with wide hardwoods (maples and exotics) and (from my experience) if I didn't keep those rollers constantly cleaned, it would not pull the stock through resulting in burn marks. I made sure the bed was clean and waxed well too. But was not much help.
IMHO, the planer is the most important machine in the shop, I have a 15" Grizzly floor machine. Has spiral cutter head and the infeed roller is steel. It's also a heck of a lot quieter than the benchtop machines.
Jon Weisenbach
You know actually the Steel City 13" planer with the helical head is on sale at Highland I think it is but @ $499 I figured it was out of his price range but it's a great planer for that price as it's normally like $700
