(OT) Math formula
(OT) Math formula
Moses Yoder
(OT) Math formula
Moses Yoder
A friend wants to know what the formula is for calculating the weight on a beam to balance the other end. I googled it with no applicable results. If you have 200 pounds on a beam extended 6 feet what is the formula for calculating how much weight it would take to balance that weight say if the beam extends 16 inches on the other side of the fulcrum?
Re: (OT) Math formula
Dave Bair, Eaton Rapids, MI
I'd think you could set up a ratio with three knowns and solve for the unknown. But I'm no math whiz.
mdclor
For the beam to be balanced, the force on each end needs to be equal. Therefore,
200lbs x 6 ft = 1200 ftlbs, so 1200ftlbs / 1.33ft = 902.25 lbs (16 inches/12 inches = 1.33 ft)
It has been a long time since HS physics, I hope this is still the correct way to do this. :)
Hal
The weight required 16" from the fulclrum to balance 200# at 6' (72") will be the ratio of 72 to 16. So the weight will be 200 x 72/16 which equals 900#. Note that 200x72 = 900x16. Hope this helps. Hal (a retired structural engr.)
I'm unclear constructing the problem
Gary Smyth
Are you telling us the beam is 12 feet long and that the balance point is at 72" loaded with 200lbs on one end or that the beam is 12 feet long and a weight of 200 lbs is on both ends and you want to move the BP 16" to one side and arrive at a new BP weight?
Remember to think about beam stiffness, too - that's quite some weight to be cantilevered out there six feet from the support point - and how the beam will be seated.
Just balancing forceXdistance...
John in NM
As others have said. However, if the beam is large, it will have enough weight of its own to affect the balance and it needs to be balanced as well, assuming a point load at the center of gravity for each portion.
Howard Norman
The calculations given here that says you need ~900 lbs on the other end have one problem. That is they do not take the weight of the beam itself into account. If the beam was weightless the numbers would be correct however in practice that will not be the case.
Clint Searl
Clint Searl
200lb x 72in = 'A'lb x 16in
'A' = 200lb x 72in / 16in
'A' = 900lb
Plus for the weight of the beam itself:
'Beam'lb/in x 36in = ('B' x 16in) + ('Beam'lb/in x 8in)
'B' = (('Beam'lb x 36) - ('Beam'lb x 8)) / 16in
'B' = ('Beam'lb) x 28 / 16in
'B' = 'Beam'lb x 1.75
So if the beam weighs 100lb, the added weight needed to balance everything at the 16 inch point would be 175 pounds, for a total of 1075 pounds.
I think! :\
Clint
ThomD
You could use the same math to judge the beam weight, so either weigh your beam, and place those proportional weights at the centers of the lever arms (half way out each arm), or you can easily calculate beam weight from approximate wood density numbers. With two values, you have to solve a slightly more complex problem.
In addition to the beam weight you also have to factor for the distribution of the load itself. This kind of math comes up a lot in boatbuilding where one has to factor the weight of everything into the design. The toilet, the mast, everything will affect how the boat sits on it's lines. Even a small boat like a kayak has issues. One would have to model where the center of the paddler weight is, since he isn't standing at a point, but sitting which distribute the weight ahead of his butt contact point, due to the weight of his legs. There is a spreadsheet method for doing this stuff.
The teeter totter example here is what you may be after, you can read around moments, centroids, static equilibrium, etc... http://ltcconline.net/greenl/courses/106/WorkForceMoments/centroid.htm
Sometimes the easiest solutions for the math challenged (as in don't know the formula, regardless of how comfortable one is doing it) is to mock it up with a simple little scale model.
