Interior painting/patch questions OT
My son and I are working on a house I bought at foreclosure that he wants to buy from me. I was rode hard and put away wet. Lots of wear and tear from having been a rental.
Must have made a hundred patches in the walls, mostly the size of nail holes for pictures and the like, but some were several inches square from door knobs or the occasional fist(?). He is painting some rooms with semigloss or eggshell. The patches show in glancing light. They look like dull spots. We sanded the patches. We primed with oil based Kilz. I'm thinking we should have put on a coat of flat paint as an undercoat.
Any suggestions on how to do this and not have the patches show? I expect to do this again.
Re: Interior painting/patch questions OT
S'rock
If you've done much more than nail holes, you should prime the entire wall.
Especially do NOT use spot sealer like KILZ. Reason being that the spots will change how the wallboard absorbs moisture from the paint, and thus how much paint is "pulled off" the applicator. You will then see low spots in the topcoat that have less paint on them. Roll the bare patch and you'll get dull spots slightly raised for the same reason. You should spot prime (rather than stain-kill), then reprime the whole wall before top-coating. If you actually need stain-kill (water staining etm) spot treat, then roll the entire wall section with the sealer.
Having lived in a house that had nail pops in every stud-line in every room, I've too much experience with this. :D
Re: S'rock
We actually primed almost the entire interior with Kilz. This house was unbelievable. Some rooms had wallpaper. Some had wallpaper that had been painted over. Several rooms it looked like they bought their kids a quart of paint and let them go as far as it would. They just painted until the roller went dry. No particular start or stop, just ragged edges.
Part of the problem is that my son insisted on painting while I did technical things like repair frozen plumbing, reinstall fallen ducts, fix the rotted floor under the French door and the utility room door, repair the rotted floor under a toilet, and on and on. I lectured him on doing prep, but he was insistent on priming with the Kilz first. He and his friends. It is the Million Monkeys paint job. Now, It's Oh! It would have been better to do the prep first.!
I am just trying to figure out how to improve for the next one. He gets to live in this mistake.
Re: S'rock
Thomas Norton
As much as it pains me to say it. Maybe he should have to live with his mistakes because he refuse wise counsel. In time ,when it is his home, he will learn to do things correctly.
I guess it goes back to personel responsibility.
Joseph Mulherin, Sr
Barry, I learned long ago that to properly replace the drywall where a doorknob has made a dent is to cut a piece of drywall about 6" square; trace its outline on the wall where the damage is; then turn the piece over and remove just the drywall compound about an inch on all sides...leaving the facing paper intact....; then cut the damage from the wall and the surrounding paper on the drywall at the outlines you marked earlier; insert the patch into the wall and make sure the papers align properly; then apply drywall compound to the paper inside edges and place down on the wall around the patch....let compound dry, then apply some more compound like any other patching, sand till acceptable, then do your repainting as needed. For nail holes...enlarge the hole with a large nail set and apply compound.
Ooops
Do I understand that he primed first and THEN filled the holes? If so, go back, screen-sand the "dull" spots, then prime, then topcoat. What is happening is that the raw compound over the primer is throwing off the topcoat's gloss. If you've got a perfect wall, using higher gloss is fine, but anything over flat will show every bump, ding, and texture change. You can get almost the same "washability" as eggshell by going to a quality flat enamel. Consumers Reports just rated the Orange Borg's Behr flat enamel paint as #1 and a best buy at $17/gal.
