Teak prices - why so expensive?
I've seen the dowel prices in the McFeelys catalog - and I'm not sure if they are tongue in cheek or not. I've seen prices of $12/ bd. ft. in other places.
I've never really worked with teak - is it worth the price? Should I be on the lookout for teak?
Re: Teak prices - why so expensive?
Moses Yoder
Moses Yoder
Wood is generally priced on a supply versus demand basis. If the supply is low and the demand high, the price will be high. Teak is a very weather resistant wood and looks good where someone wants a nautical theme, so it is not only in demand for boats but also for home furnishings.
Confused...
John in NM
Are you comparing prices on dowels to bdft pricing? Obviously I haven't looked at McFeely's lately.
About 5 years ago, teak was right around $15/bdft, IIRC. Then it went up fast to about twice that, at least around here. One can only hope its dropped back down to reasonable levels.
By all accounts, teak is exceedingly weather proof. Trouble is, joints aren't. Seen lots of factory made "outdoor" furniture that is falling apart after 10 years or so because it's put together with dowels and pva.
Bob Hackett just mentioned using it for hammer handles over on the hand tools board. I made one once and broke it within a week (claw hammer, teak would probably work better for little tappy hammers, but then anything stronger than basswood would too). Its also the only wood I've worked with that actually lives up to its reputation for dulling steel blades quickly.
On the plus side, the stuff makes the best cutting board you've ever seen :D I also really like the feel of it for tool handles, its very grippy. I have enough scrap left from my one teak project to make a couple gunstocks, they're going to look very utilitarian, but I bet the feel will be perfect. After that, I doubt I'll ever buy more of it.
Thomas S Stockton
What Moses said is correct, but I will add some specifics for teak.
$12 a board foot for teak is actually a very reasonable price and the material is probably plantation grown outside of it's normal growing area. The plantation grown stuff isn't as nice but it works well for outdoor projects and is about half the cost.
Most commercially available teak is from Burma and sales are tightly controlled by the government to keep prices high, there is also a fair amount of illegal harvesting going on since demand is so high. When the British controlled Burma they had a really good system in place for teak harvesting that was very sustainable and kept the supply consistent.
Countries like Indonesia that produce a lot of teak furniture have pretty much outlawed shipping raw lumber out of the country. They require that the wood be processed a certain amount in order to export it, usually this means it needs to be made into furniture or furniture parts.
You asked if you should be on the lookout for teak and my answer would be if you need it for an outdoor project, yes it is great for that. For indoor projects it is not one of my favorites and there are a lot of other options out there that I like more. There is one term you will run into when dealing with teak and that is FEQ which is "first european quality" that is the top of the line stuff similar to FAS.
Tom
paul in AZ
$12/BF is pretty cheap. Teak runs as much as $30 here. More in many places for better grades.
There is a caveat though. There is teak and there is teak. Some of the stuff is pretty junky and is not what some call 'marine grade'. Chinese made patio furniture you see around is mostly pretty crappy teak.
No matter the grade it does eat sharp edged tools. I once needed a teak board for my boat and an old timer gave me a gorgeous board he'd had for years. He had a complete shop and at the time and I had almost nothing. He gave it to me for free on the condition that I not ask him to mill it for me. Tough stuff loaded with edge destroying minerals so he didn't want to resharpen his tools.
Re: Confused...
Thomas S Stockton
I made a really sweet little hammer handle out of bubinga, didn't last more than a couple of days. Then there was the pearwood bench dogs looked great didn't last long, my current set is white oak and they are about due to be replaced after 12 years.
Tom
Same here
Tony - Memphis
I bought several thick boards (8/4) a few years ago to build a garden bench. It was on sale. Otherwise, I wouldn't have bought it. It is beautiful. The color is really nice when finished with an exterior oil like Teak Oil (imagine that). It was not hard to work. I even carved volutes in the arms of the bench. But boy did it dull my tools! It even dulled tools it was stored next to! I have a few pieces left that I use for small outdoor things, but I dread using it because it dulls everything so quickly. It is really pretty though. This bench is outside but on a covered patio. The color is holding up so far. I do need to scuff it and apply a new coat this year. Still a nice golden brown though.
Tony
Re: Iroko
ThomD
Look around at Iroko prices. It is a reasonable substitute depending on the use.
An on-line auction place is selling teak.
I was wondering what would be a reasonable price.
As the lots are quite large, I wanted to set an upper limit.
Re: An on-line auction place is selling teak.
Keith Newton----Little Rock, Arkansas
I think I saw that auction notice also. Wish I were nearer to take a look at it.
One of the reasons for the teak price, is that besides being durable, and high on the beauty scale, it is fairly light in weight, which makes it really desirable for use in boats above deck. There are plenty of beautiful decay resistant woods out there that are too heavy to be used where teak was used, especially on sailing vessels. Besides capsizing more easily, all of the dynamic motions in waves would be exaggerated, plus more displacement for the same use, makes it stay in high demand.
If you are not needing it for a boat, I would think about using other woods, due to the other problems, like dulling of tools.
